Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
HID question
Old Feb 21, 2010 | 06:47 AM
Igaly's Avatar
Default HID question
what EM crew? I got this question, im ordering new projector headlights and the lowbeam is H1 and I want to go with 10K HID's will it work fine or do you guys think is to bright cause my other projectors were lowbeam H3 and I had 6K HID's and I wasnt satisfied with the brightness
Old Feb 21, 2010 | 10:02 AM
00falcon's Avatar
Default Re: HID question
anything above 6k is just color. if you want brightness stick with 6k.
ebay projectors apparently are no good for swapping in HID as they were made for regular halogen bulbs. even tyc ones are no good. i know they've started bundling hid and projector lights together but i doubt the lens quality is that great. though they may have finally figured out how to stop crazy glares.
if you want real hid projection you'll have to build your own with TSX projectors or BMW E46 ones i believe
Old Feb 21, 2010 | 10:35 AM
CHiKi's Em2's Avatar
I have 8k on my projectors and they look nice...
Old Feb 21, 2010 | 12:46 PM
jdm em2's Avatar
Eh hid's are hard to call the reason why is my buddy has 10k and he can't see a thing, On the other had i have 10k and i can see like i have 6k its just the kind/brand you get and the wattage in the ballest.
Old Feb 21, 2010 | 09:29 PM
ccbl's Avatar
^ what he said...
but my 2 cents is to not get ebay projector headlights... i heard lots of bad things about them. if you have the patience/skill/money to retrofit... that would be the way to go.. it will give you much better results and usually for the most part looks a lot better!
good luck!
Old Feb 21, 2010 | 09:35 PM
DynastyRacer22's Avatar
they do make a diy retro fit kit now already has the bulb and projectors its a little more in price but its worth it
Old Feb 22, 2010 | 03:27 PM
Vilex's Avatar
New User
I have 55w 6k and they are insanely bright. Got 'em from ddmtuning. **** is legit for $30 with lifetime warranty.
I have ebay projectors. They aren't too horrible.. Just seal them up good. With HIDs they tend to scatter the light just a tad, but not too bad. The cutoff is fairly good as well.
Old Feb 22, 2010 | 04:27 PM
Igaly's Avatar
ok guys thanx for all your help
Old Feb 22, 2010 | 06:36 PM
grnaccord's Avatar
Same question as OP but i have the single projector headlights that came with H1 low beams but factory headlights are H4 and the projectors have a h4 connector that splits and goes to my low beam h1 and high beam h3 i think. so what kit do I buy H1 or H4?
Old Feb 22, 2010 | 06:50 PM
Igaly's Avatar
u need to get h3 cuz thats the low beam h1 is high beam on your projectors......mine is different i got h1 for low beam and h11 for high beam
robbys89
Feb 9, 2009 09:44 AM
Import_2
Lighting
Dec 27, 2007 08:40 AM
viskii420
Lighting
25
Oct 31, 2007 04:21 PM
4_door_eg
18
Apr 3, 2007 01:24 PM
sniperslayer
16
Jan 20, 2006 10:58 AM
