Popping noise from exhaust..missfire? Please help!
Old Feb 21, 2010 | 12:21 AM
knakmuhs's Avatar
Default Popping noise from exhaust..missfire? Please help!
ello everyone! My name is Chris!
I am new to HT and Honda cars in general.
My car is a 1992 Civic VX hatch with the stock VTEC-E d15z1 motor and a cold air intake...that's it!
My car seems to be missing at idle. You can hear a popping/poofing noise from the exhaust pipe. Anytime other than idle, the car performs good!
The idle also gets extremely low when the headlights are turned off. When I turn the lights back on, the idle smooths out a little, but it still misses.
I did the following in hope of solving the problems: New plugs and wires, new fuel filter, and I cleaned the IACV. I was going to replace my PCV but, the PCV that was already installed was just a hallow L-shaped tube.....could this have anything to do with my problems?
The alternator was recently replaced by the previous owner (supposedly). The distributor on the car looks brand new... Could the person who installed the new distributor possibly messed up the ignition timing? or would timing have nothing to do with idle?
I don't have a CEL. Maybe I need to reset my ecu or something?...to see if one might come on?...
Maybe I should go through and check all of my electrical stuff? I have a multi meter, so I'm sure I could check things if someone went over the procedures me (I'm pretty new to these type of things =p)
Here is a few things that people have suggested I inspect : Catalytic converter (possibly clogged?), Fuel injectors, Vacuum leaks, bad 02 sensor, incorrect ignition timing, exhaust leak, etc..
I'm sorry for writing a book but, I'm desperate to figure this out! This miss/noise is driving me crazy!!
Please help me if you can!
Thank you! - Chris Knakmuhs
cjwang2
Nov 24, 2014 02:16 PM
edogmb
May 13, 2012 08:34 AM
knakmuhs
Feb 17, 2010 10:54 PM
SI_frankenstein
May 15, 2008 02:42 PM
Chilly61383
16
Nov 12, 2005 05:23 PM
