coolant leak
Old Feb 20, 2010 | 08:25 PM
patwitahonda's Avatar
Default coolant leak
I have a 91 civic hatchback with a b16a. I noticed i was losing coolant and didn't see any leaks. But then i noticed a puddle on my passenger side floor. Anyone know where it could be coming from?
Old Feb 20, 2010 | 08:38 PM
hatchet_honda's Avatar
Default Re: coolant leak
coolant inside on the floorbaord you sayy? sounds like you have a leaking heater core.
Old Feb 20, 2010 | 08:50 PM
yea is there anyway to stop it?
Old Feb 20, 2010 | 10:44 PM
D16SiHatch's Avatar
yep. you can park the car and not start the engine..
or..
replace the heater core
Old Feb 21, 2010 | 08:56 AM
is there a way i can delete the heater core?
Old Feb 21, 2010 | 09:44 AM
racingcrx's Avatar
yes there is. but you will not have any heat
Old Feb 21, 2010 | 09:51 AM
Can you direct me to a write up on how to delete it?
Old Feb 21, 2010 | 11:04 AM
OddityDX's Avatar
just make a loop with the hoses that connect to the heater core.
Old Feb 21, 2010 | 12:31 PM
is it not winter in illinois right now? cause in in indiana and its like 12 ****in degrees. id think youd kinda need a heater in your car.
Old Feb 21, 2010 | 01:28 PM
Je2RiT's Avatar
As stated above. Make a loop from the back of the block (that goes to the firewall)
to the other hose to the back of the block (from firewall to block).
Both hoses are beneath the Intake manifold.. So:
Unscrew the drain bold in your radiator. (below passenger side of the tank)
Drain your coolant.
Then re-route the coolant lines.
Screw your drain plug back in.
Fill your coolant.
Bleed your coolant system.
Bada-Bing!
Old Feb 21, 2010 | 07:31 PM
D16SiHatch's Avatar
well i would have told him that bypassing the heater core is an option, but i assumed most people would rather keep there heat.. guess i was wrong. whatever floats your boat i guess
Old Feb 21, 2010 | 08:17 PM
EFRue57's Avatar
granted this is from a corolla but it will be very similar to your Honda as well. where these two hoses come out from your firewall to your motor, just disconnect the hoses from the inlet and outlet like stated above and then find a u-bend hose that fits the space between the outlet and inlet on the motor and viola, no more leaky heater core.
Ayashifx55
Dec 23, 2010 10:01 PM
deechiguy
Mar 4, 2005 08:53 AM
zman
Jun 5, 2004 08:58 PM
eternity0114
May 10, 2004 02:27 PM
