jdm itr header in 95 civic b18 swap
Old Feb 20, 2010 | 05:53 PM
mcgruff's Avatar
Icon3 jdm itr header in 95 civic b18 swap
ok so obviously im going to have to upgrade my stock 95 civic 4dr exhaust to match my 2.5" jdm itr exhaust manifold once i swap. will the rest of the jdm integra type r exhaust sytem match up with my car? how much fabricating would be involved to make it work? does any company out there make a simple bolt on system? i really dont want to have to get all custom and have pipes bent, more of a trust issue i guess...
any input is greatly appreciated
Old Feb 21, 2010 | 06:08 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: jdm itr header in 95 civic b18 swap
The rest of the system will fit but you'll need to lengthen the exhaust tip as the stock muffler will be sitting in just under the bumper on your car.
Old Feb 21, 2010 | 09:47 AM
mcgruff's Avatar
ok so all the hangers will match up alright and it wont be hanging down or anything sloppy?
and my collector is 2.5" but after the cat does it drop down to 2.35"? most of the jdm itr catbacks ive seen for sale boast 2.35" piping... i thought that was usdm dimensions..
example: http://passwordjdm.com/JDM-ITR-Cat-B...P1689C210.aspx
p.s. will i pass us/canada emissions with jdm itr cat (the small one)?
Old Feb 21, 2010 | 09:57 AM
00Red_SiR's Avatar
All Motor Mentor
It should sit like a factory exhaust does. I do believe it necks down after the cat to the 2.35 size. I don't know if it's capable of passing the emission tests or not. I guess it depends on how stringent the rules are.
Old Feb 21, 2010 | 12:24 PM
mcgruff's Avatar
thanks for help, that would make sense based on my search results.. so a usdm type r cat back should fit the same, maybe with some compensation for the larger cat? more research i guess... im moving to vancouver, bc in july but my inspection for the us (texas) is good for another 10 months. being from canada do you know anything aout BCs emissions policy? i know theyre quite eco-friendly...
Old Feb 21, 2010 | 01:35 PM
mcgruff's Avatar
and what is this "b-pipe"?!?!?
from cat to axle?
Old Feb 21, 2010 | 01:45 PM
00Red_SiR's Avatar
All Motor Mentor
I live in Nova Scotia which is at the other end of the country so I'm not too familiar with BC's emission laws but I would imagine you could find that info online fairly easily. Yes, the "B" pipe goes from the cat back to the axle. You'll like it there, it's a beautiful province that we often call "The Canadian California".
Old Feb 26, 2010 | 12:36 PM
fungus mungus's Avatar
A b-pipe is the tube between your header and your cat (assuming you have a 2-piece header)
fm
Old Feb 26, 2010 | 03:08 PM
00Red_SiR's Avatar
All Motor Mentor
fm
no it isn't.
Old Feb 26, 2010 | 03:56 PM
Right you are. I was referring to the down pipe. My brain fart. Back to our scheduled programing.
SoCal ITR
Feb 5, 2007 09:25 PM
usher13
Jan 9, 2003 10:50 AM
comptechgsr
May 20, 2002 09:26 PM
comptechgsr
May 18, 2002 11:39 AM
brwnrice
Aug 8, 2001 03:54 AM
