Valve Cover Question
Old Feb 20, 2010 | 03:41 PM
ReVeNgEd-SoN's Avatar
Default Valve Cover Question
So i'm cleaning up my valve cover and trying to get rid of all the oil on the inside for a clean cover before I paint and was wondering what anyone did to get rid of all that oil residue on the inside? I can't scrub between all the little cracks to clean it well.
Also, anyone have any recommendations on cleaning the engine up and the metal components well without removing the engine or hurting anything around it? Thanks in advance.
Old Feb 20, 2010 | 06:31 PM
MrExclusive's Avatar
Default Re: Valve Cover Question
Brake cleaner??? Degreaser??? Then pressure wash the engine bay???
Its what I would do...but hey im no pro to give advice...just my opinion
Old Feb 20, 2010 | 08:31 PM
vtechjunkie's Avatar
No matter how much you soak, degrease, or scrub your motor, it will almost always look dirty. The oily dirt penetrates the metal. The best thing you can do is bead blast it and then paint it. That will seal off the little cracks and all the old residue. It will also make it much easier to clean later. If you can't decide on a color, then just go silver. Then it LOOKS like you got it all the way clean. LOL!
Old Feb 20, 2010 | 09:58 PM
thumper64's Avatar
Spray it with oven cleaner and spray it off at the car wash. Same thing as hot tanking it but much cheaper.
Old Feb 20, 2010 | 10:33 PM
D16SiHatch's Avatar
yea just spray it with some decent cleaner or degreaser and get out what you can. i would highly recommend you NOT bead blasting the inside of the valve cover. it will be next to impossible to remove all the material that will inevitably be wedged into all the crevices. i'm sure it doesn't take a lot of imagination to figure out what that particulate could do to your valvetrain/engine in general
VTECisSeXY
Dec 15, 2005 08:50 PM
SilverSpeed
Jun 9, 2003 06:41 PM
vicz
Apr 10, 2003 02:02 PM
vicz
Mar 5, 2003 08:24 AM
nsx-Animal
Mar 19, 2002 08:32 AM
