car wont start need help????
Old Feb 20, 2010 | 03:33 PM
honda_gsr_b18c's Avatar
Default car wont start need help????
i have a 94 gsr and i slowed down at a stop and it was like going five miles a hour and i dropped in into 1st and then my clutch stuck to the floor and and i had to push the gears in to make it home and the next day i tried to start it and it wouldnt start its not the relay and i bleed the clutch and changed the master clutch cylinder so i am out of ideas i need help please help
Old Feb 20, 2010 | 06:25 PM
db-1charlie's Avatar
Default Re: car wont start need help????
throw up bearing is busted.
Old Feb 20, 2010 | 06:39 PM
dudesitsjdm's Avatar
this is it for sure.throw out bearing
Old Feb 21, 2010 | 02:31 PM
ok thanks i will check that cause i replaced my slave and clutch sensor so i will check it and let ya know
Old Feb 21, 2010 | 02:36 PM
also i forgot to mention that when i turn the key it does nothin at all like the clutch aint pushed in but i checked the sensor right there under the dash the bottom one does anyone know what the top sensor is also
Old Feb 22, 2010 | 08:17 AM
do your lights in the dash come on? are you getting power?
Old Feb 24, 2010 | 06:47 PM
ok your not gonna believe this but i figured it might be the safety switch right so i am puttin the new one in and notice the small piece of plastic on the clutch petal that pushes the button on it is missin it had broken off the same time the slave went bad cause thats what caused my clutch to stick so needless to say i was kinda mad when i found out it was something that simple but thanks for helping me
93sivtec
Jan 20, 2008 03:16 PM
91H4hatch
Jan 16, 2008 01:16 PM
civicpark81
Nov 1, 2007 08:18 AM
0ptimus prime
13
Feb 25, 2005 02:39 PM
sshaikh01
Feb 5, 2002 12:35 PM
