Can Running a Motor With NO Thermostat be harmful to the motor?
Old Feb 20, 2010 | 11:15 AM
cerealbox575's Avatar
Default Can Running a Motor With NO Thermostat be harmful to the motor?
i swapped a b20 into my teg. only problem i had was it kept over heating. well the fan wasnt even turning on so i thought that was the problem, i wired a switch and it still over heated. i squeezed the top hose from the RADIATOR to the HEAD and there was no coolant. my friend suggested i take the thermostat out and run it like that. i did it and problem solved. at first start up it will read cold and after driving it will get to operating temp. but with no thermostat could this harm the motor? im planning on taking a 18 hour trip and just dont want any surprises.
Old Feb 21, 2010 | 02:05 AM
Jangles's Avatar
New User
Default Re: Can Running a Motor With NO Thermostat be harmful to the motor?
My b16a3 sat in a shop for yeeaaaarrrsss. So when I got it the thermostat was stuck open I guess, but it never overheated, and in cold weather it would actually drop back down towards cold.. So my AEM cai helped out a lot more that way. It just sucked because my heat wouldn't warm up!. But no surprises for me, just remember to turn your fan on
Old Feb 21, 2010 | 04:08 AM
Matt93eg's Avatar
The correct way would be to find out "why" its overheating and fix it the right way, running with no Thermostat usually will not allow the engine to reach full operating temp, its not good to constantly drive and engine below operating temp. The engine you had in your Teg before you swapped in the B20(I assume an LS), did it overheat?
Fix this the right way and not half *** by taking your T-Stat out, that's my opinion.
You say you wired to fan to come on and it still overheated, but once you took the T-Stat out the overheating problem was solved, it sounds to me the T-Stat you took out was "Stuck Closed" never allowing the coolant to fully circulate between radiator and engine thus causing the engine to overheat. I would put a "new" T-Stat in there and see if that fixes your problem, then you will run with the engine at Operating temp and have heat as well.
Old Feb 21, 2010 | 05:17 AM
Kyle R's Avatar
^That sounds like a likely solution.
Old Feb 21, 2010 | 06:36 AM
fcm's Avatar
fcm
Old Fart
Ditto the above, install a thermostat, running an engine at below normal operating temp. is not a good thing, at the very least you will get crappy MPG and emission system will not operate properly.
Old Feb 21, 2010 | 06:37 AM
Scott_Tucker's Avatar
Its not something that is going to damage your engine overnight but your engine will wear out early. You should always run a thermostat in a street car, there is no excuse not to.
Old Feb 21, 2010 | 03:55 PM
well ill try that soon. i really do want it running the right way. cuz i just want to have that piece of mind that my car is in tip tiop shape on a 17 hour drive.
Old Feb 21, 2010 | 07:00 PM
BrandonR's Avatar
Thermostats are under 10$. Mine was was a STANT one 7.89$. I'd put in a new one before your trip since there not expensive and you should have one like everyone is saying.
Old Feb 21, 2010 | 07:27 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
As a good measure you might also consider replacing your radiator cap. The radiator cap actually helps the cooling system pressurize, which raises the boiling point of the coolant. You can also lose coolant if the cap doesn't make a good seal.
Old Feb 21, 2010 | 07:49 PM
You also may want to install that thermostat a couple of days before you leave on your trip so you can confirm that the engine is not going to overheat. It would suck to do it the night before the trip only to find out that morning that the engine overheats after an hour driving.
Old Feb 22, 2010 | 05:42 AM
Matt93eg's Avatar
X2, yeah don't wait until the last minute, because if it still overheats it would spoil your day pretty quick, I am betting the new T-Stat will take care of it. Also like PatrickGSR said, it never hurts to replace the radiator cap. There cheap as well.
simplegreenmachine
13
Dec 12, 2009 04:07 PM
jth8448
Feb 5, 2008 09:55 PM
B20TDC2
Jul 30, 2005 07:31 AM
philosofy1
Jun 14, 2005 05:45 PM
juicedricer
Jan 21, 2003 04:55 AM
