90 accord ground problem ?
Old Feb 20, 2010 | 10:59 AM
stang7043's Avatar
Icon2 90 accord ground problem ?
Ok so my front blinker was acting funky the past few weeks. Thought I had a bulb going bad. Replaced all the bulbs with brand new ones just to be on the safe side. Seemed to be ok for the next few days but then it started acting up again. The blinker will flash properly for about 6 times then die and I get the rear flasher blinking fast for about 10 secs then it starts working again. Ive also noticed over the past few days that my wipers are starting to act funky as well. They wont stop after I turn them off for about 10 secs. Or they will skip stop wipe stop skip and also noticed when my wipers are acting up the left turn signal indicator on my dash dimmly lights when the wipers move. Im pretty sure I have a bad ground because the left signal and wiper motor share the same ground. So I looked it up and it says left front corner ground G. For the life of me I cant find the ground (bar?) in the front left corner. Can anyone direct me to where it is or post a picture... Thanks
If it matters:
1990 Accord 2dr lx
4cyl
MT
Old Feb 20, 2010 | 11:25 AM
redbull-1's Avatar
Default Re: 90 accord ground problem ?
See this link for location and picture of ground G301.
http://www.superhonda.com/forum/f13/...t-help-314079/
Old Feb 20, 2010 | 01:37 PM
stang7043's Avatar
Didnt end up being the problem. There was some type of relay that wasnt bolted down tightly. Cleaned the metal around the bolt. Bolted it down tightly working great now. Thanks for pointing me in the right direction.
Old Feb 20, 2010 | 01:43 PM
redbull-1's Avatar
Glad you fixed the problem. BTW the ground is like a box with other wires connected.
It looks like a box - 1.5" tall, 1.25" wide, 0.5" thick. It has 8-10 black wires going into the bottom of it.
Dannyx321
May 1, 2016 04:06 PM
tauberj
Dec 10, 2014 04:29 AM
wojtkows
Mar 29, 2010 10:07 AM
hydrolicman
Apr 7, 2009 02:23 PM
vchandna
Feb 14, 2009 10:59 AM
