gsr cluster swap question
cluster works fine, except the speedo does not work. Are you suppose to use the small plug thats on the crx harness and plug it into the the gsr cluster? Thats the only thing we can think of, of why it's not working.
the crx VSS (vehicle speed sensor) is mechanical (cable driven) but all newer clusters including your gsr cluster use an electric VSS. replace the VSS and wire it up to the cluster.
good luck
good luck
I have an electrical vss already installed and wired up, but it still doesnt work.
thats for cruise control,
have you checked the vss wiring?
the electric VSS sensors have plastic gears, its possible that the gear is just shredded, pull it out and check it.
B16Civic93
Feb 21, 2012 02:15 AM
wesleywhite989
13
Jul 18, 2008 07:18 PM
