Finishing swap, PLZ HELP!
im finishing my b18b1 swap in my civic but i am having problems running the hoses in the back as i have forgotten where they go. can you guys tell me where these lines go?
Both Charcoal canister lines.
IACV on the Intake manifold lines.
And Last the black pipe connecting the water pump and thermostat has 1 hose coming off that pipe. where does that go?
I've been having trouble finding good diagrams online and don't wanna hook up a coolant line into a vacuum hose on accident
Any help is appreciated! I wanna get this 350hp beast on the streets asap!
The bigger charcoal line goes to the upper port on the throttle body. Newer throttle bodies don't have the connection. The smaller one goes to the EVAP purge solenoid on the port that goes out to the side, not the bottom.
One IACV line comes from the lower section of the throttle body. It exits out the other IACV line to the black pipe you're mentioning.
Thanks you so much. i have most of it all straightened out now, but i cant locate the purge solenoid. Do i not have one? car is 1997 civic engine B18b1 -1997
prelude9999
Oct 8, 2004 10:01 AM
