Where's a good place to draw oil for the feed line for my turbo on my b18b1?
Old Sep 6, 2002 | 06:21 PM
freeplay's Avatar
Default Where's a good place to draw oil for the feed line for my turbo on my b18b1?
I've heard that the set screw on the side of the head is a good spot (right by where my VTEC sylonoid would go. It seems too small though. Also, what is a good size line to run? Is 1/4" ID good enough? Thanks to all.
Riley
95 Integra
Old Sep 6, 2002 | 06:43 PM
Smashback's Avatar
Default Re: Where's a good place to draw oil for the feed line for my turbo on my b18b1? (WannabeTurbo)
1/4" is the largest you'd want to use. Not sure on using the head port, perhaps somebody with a B series can answer that.
Old Sep 6, 2002 | 06:49 PM
rjardy's Avatar
Default Re: Where's a good place to draw oil for the feed line for my turbo on my b18b1? (mplex2000)
best to t it off from your oil sending unit!
Rob
Old Sep 6, 2002 | 08:09 PM
freeplay's Avatar
Default Re: Where's a good place to draw oil for the feed line for my turbo on my b18b1? (rjardy)
And could you please tell me where the oil sending unit is located? Thanks,
Riley
Old Sep 6, 2002 | 08:26 PM
bigstatik's Avatar
center rear of the block
Old Sep 6, 2002 | 08:32 PM
TurbothisLS's Avatar
Default Re: Where's a good place to draw oil for the feed line for my turbo on my b18b1? (bigstatik)
next to the oil filter. it has a rubber cover over it and wires running to it.
Old Sep 6, 2002 | 08:54 PM
bigstatik's Avatar
Default Re: Where's a good place to draw oil for the feed line for my turbo on my b18b1? (TurbothisLS)
wrong sir, it does not have a rubber cover and it only has one wire going to it.
its to the left of the oil filter.
Old Sep 6, 2002 | 09:53 PM
freeplay's Avatar
So even if it is below the turbo, it has enough pressure to pump up to the turbo level? Is it OK to just tee into it then? If I hook it up, and I want to make sure it's working, can I turn the car on for a split second to make sure it shoots out of the tube? Also, for the first time a turbo is installed, is there enough lube in it to run on it's own for a second until oil reaches it, or do i have to prime the line or something like that. Thanks a lot fellas.
Riley
Old Sep 6, 2002 | 09:55 PM
bigstatik's Avatar
yes it will reach 50-70 psi, and yes u should prime the turbo before starting
Old Sep 6, 2002 | 09:58 PM
freeplay's Avatar
Do you happen to know what size the pipe is I'll need to tap? I guessing a barbed brass "T" will work. Sorry I'm a pain. Thanks,
Riley
Old Sep 6, 2002 | 10:00 PM
bigstatik's Avatar
the thread size into the block is 1/8" NPT
[Modified by bigstatik, 2:00 AM 9/7/2002]
Old Sep 7, 2002 | 05:51 AM
DRAGLS's Avatar
On my b18b i got my turbo oil feed from the side of the head it's a 10x1mm thread
Old Sep 7, 2002 | 08:08 AM
93LSivic's Avatar
Riley
95 Integra
Last I checked the B18B1 motor didnt have vtec
To answer your question you want to use the location at the back of the block where the oil pressure sensor is.
Old Sep 8, 2002 | 07:08 AM
johnisenglish's Avatar
Default Re: Where's a good place to draw oil for the feed line for my turbo on my b18b1? (93LSivic)
I think he was saying where the solenoid WOULD go, if he had a B18C1.
Old Sep 8, 2002 | 07:29 AM
sutrusu's Avatar
Riley
no you have to crank the engine so the oil flows through it!!!!
memorize this website http://www.cse.uconn.edu/~yelevich/turbo/turbo.html
Old Sep 9, 2002 | 07:00 AM
"On the left side of the oil filter, you will see an oil sensor which has some sort of rubber boot on it."
straight off the Turbo 101 website.
i've removed this before and i know there is a rubber cover over it...
Old Sep 9, 2002 | 07:31 AM
boomslang's Avatar
The oil pressure sensor thread size is 1/8" bspt. Not npt. Use a bspt to npt adapter from Z10 or Autometer. Not doing so may result in fugged up threads and/or oil leaks. Use teflon paste.
Don't tee off the back of the block.
Old Sep 9, 2002 | 08:13 AM
GraphiteAccord's Avatar
Default Re: Where's a good place to draw oil for the feed line for my turbo on my b18b1? (Inlinefour)
On that turbo 101 site, he doesn't mention anything about putting the oil pressure sending unit back on...would this be ok with a OBD1 car? The ecu wouldn't throw a cel with it like that?
Old Sep 9, 2002 | 08:19 AM
boomslang's Avatar
Default Re: Where's a good place to draw oil for the feed line for my turbo on my b18b1? (GraphiteAccord)
You need the sending unit attached.
Old Oct 18, 2002 | 03:32 AM
blufke's Avatar
so what is a good way to go about having the oil feed and an aftermarket oil pressure gauge sensor along with the stock oil pressure sensor?
Old Oct 18, 2002 | 06:19 AM
b18bturbo's Avatar
Default Re: Where's a good place to draw oil for the feed line for my turbo on my b18b1? (blufke)
Best bet for thta is build a oil feed tee unit. It simple jsut need 4 port tee run 1/8/bspt fitting to 1/8npt then run -4 line to that tee then from there run all yuor accesories best thing to do.
Old Oct 30, 2002 | 07:07 PM
blufke's Avatar
Default Re: Where's a good place to draw oil for the feed line for my turbo on my b18b1? (b18bturbo)
where is a good place to get a 4 port tee?
Old Oct 30, 2002 | 07:31 PM
Vu's Avatar
Vu
Where else on the block can you get oil supply from, besides the oil sender by the oil filter? What if that spot is already used for an LS/VTEC conversion?
Old Oct 30, 2002 | 08:04 PM
Vu's Avatar
Vu
Default Re: Where's a good place to draw oil for the feed line for my turbo on my b18b1? (Vertigo)
4 way tee, duh
But will it be able to supply enough oil to feed both the VTEC head and the turbo?
Old Oct 31, 2002 | 01:37 AM
Arturbo's Avatar
Better than steak
25 Year Member
You want to use -3 line, not a -4.
art
