Transmission & Drivetrain Gearboxes, Differentials, Clutches
odd feel in the shifter.
Old Feb 19, 2010 | 06:51 PM
projectTeG's Avatar
Default odd feel in the shifter.
ok, im driving around and the car shifts normal. has the typical 3rd scratch at 8k and all. but when im driving and go to down shift without rev matching i cxan feel the gears spining and engaging. i know this is not normal it just started out of now where and its geting on my nerves. what all could this be? a bearing? i have a little bit of a extra noise from the tranny while cruising.
Old Feb 19, 2010 | 09:29 PM
projectTeG's Avatar
Default Re: odd feel in the shifter.
nvm, it moved right into a straight rattle knock sound when you apply load to the engine at coasting no noise....at load it sounds like a motorcyle or moped....this trans is hitting th dumpster...
Old Feb 19, 2010 | 10:48 PM
Adamvanxxx's Avatar
I have the same exact problem right now. It's driving me nuts, I cannot figure it out. LMK if you figure it out.
Old Feb 19, 2010 | 11:03 PM
projectTeG's Avatar
it sounds like a card in bike spokes...its weird. im guessing its the spider gears in the diff
Old Feb 20, 2010 | 01:51 AM
projectTeG's Avatar
would there be that much of a change from going from a b16 cable tranny to the small spline 4.4fd s1 cable ls tranny? thats all i can find right now and i dont want the car to become a complete dog.
Old Feb 20, 2010 | 07:25 AM
Adamvanxxx's Avatar
I was told it was most likely a syncro gear. Which would make sense in my case, because if I do not rev match its hard to shift and then that loud grinding, whining, baseball card in the bike spoke noise. I have also been told possibly the input shaft bearing or the throwout. And I would feel skeptical buying the s1 tranny, I would just stick it out and buy another b16 tranny or a ys1
Old Feb 20, 2010 | 07:49 AM
projectTeG's Avatar
see and thats the thing. it does it in every gear and its not hard to shift...
Old Feb 20, 2010 | 01:11 PM
Adamvanxxx's Avatar
Then I have no idea. It is way too cold here to take my tranny out and take a look. Does it make the noise while you push the clutch in?
Old Feb 20, 2010 | 01:26 PM
xzodiackillerx's Avatar
ISB? sounds like marbles in the damn thing
Old Feb 20, 2010 | 03:19 PM
projectTeG's Avatar
it goes away hen you remove the load from the engine. im wondering i replaced the isb in the front but did not do the rear one
Old Feb 21, 2010 | 05:01 PM
projectTeG's Avatar
Old Feb 21, 2010 | 05:27 PM
projectTeG's Avatar
what would cause that discoloration in the shift fork in the first picture?
kaj
Apr 21, 2012 10:39 PM
heeltoehonda
May 14, 2010 08:58 AM
Cripton805
Nov 21, 2009 04:04 PM
goldenhatch13
Jul 2, 2008 08:53 AM
b16hybridsol
19
Dec 17, 2004 10:27 PM
