Classic Hondas All Pre-1988 Hondas.
87 CRX idle problems,PLEASE HELP!!!
Old Feb 19, 2010 | 02:49 PM
draygunn's Avatar
Icon3 87 CRX idle problems,PLEASE HELP!!!
ok so i have this 87 CRX,i was told it was an SI by the person i bought it from but there is no tags stating that it is so idk,ither way i belive it has a D15 in it ((stock motor nun the less)) and the idle was bouncing between 2 and 2 1/3rd then i pulled up on the peddel thinking the peddel maybe be sticking and may be part of the issue and the RPMs dropped to idleing between 1 and 1 /2 and i can not think of what this may be.this is my first classic honda so i dont know a whole lot about there workings.im going to try to upload a video of gage and motor so you can see and hear,PLEASE HELP ME!!!
Old Feb 19, 2010 | 02:54 PM
draygunn's Avatar
Default Re: 87 CRX idle problems,PLEASE HELP!!!
here is the video,THANK YOU!!
http://www.youtube.com/watch?v=VcqLa9pE2No
Last edited by draygunn; Feb 19, 2010 at 02:55 PM. Reason: sorry embeding didnt work
Old Feb 19, 2010 | 03:00 PM
78CITYTURBO's Avatar
CRX SI has a sunroof, D15 fuel injection, red SI badge somewhere on the back.
http://www.redpepperracing.com/wiki/...njected_engine.
Search on the site, plenty of solutions. Good luck.
Solution is in this link, read down in the page. Good luck.
https://honda-tech.com/forums/classic-hondas-106/87-civic-si-starts-but-wont-run-2716084/
Old Feb 19, 2010 | 03:03 PM
Old Feb 19, 2010 | 03:04 PM
Yes, you car is an SI. What is the red light on the tach?
Old Feb 19, 2010 | 03:06 PM
draygunn's Avatar
sunroof and fuel injection both.red light is just parking break.thank you ill look that page up now.
Old Feb 19, 2010 | 03:09 PM
draygunn's Avatar
my alternator is good,i let it run and took off the battery to check before i posted but ill check belt tension. thank you.
Old Feb 19, 2010 | 03:10 PM
draygunn's Avatar
O and PGMFI light comes on when i turn key befor i start it,could this be an issue?
Old Feb 19, 2010 | 03:18 PM
If you your PGMFI stays on when the car is running, either the fuel pump or the alternator will take a crap, it's either one of those. It's been a while, bad memories, getting old.
Old Feb 19, 2010 | 03:38 PM
draygunn's Avatar
ha ha ha i hear ya there.the pgmfi light goes off a second or so after i turn key to the run position without starting and dosenot turn back on.
Old Feb 19, 2010 | 04:06 PM
You have to take this thing off and clean the inside of it really, really good. It's right behind the throttlebody towards the firewall.
http://www.redpepperracing.com/techn...b/aap.png.html
Old Feb 20, 2010 | 11:51 AM
draygunn's Avatar
ok cool,i never got around to working on it yesterday so i will try that and make sure belt tention is good then ill repost.thanks alot
Old Feb 20, 2010 | 01:48 PM
draygunn's Avatar
ok so i cleaned that out and it didnt make a difference,i didnt adjust belt tension but i will do that later and update.
Old Feb 21, 2010 | 12:00 PM
asdfyellow's Avatar
My 87 Civic Si does this too! It does it randomly though. I just figured it was vacuum leak.
Old Feb 23, 2010 | 02:17 PM
draygunn's Avatar
i dont know,i picked up this car as an iffy runner at best and it craped out on me then one day i was abel to start it back up.but ither way i cleaned out that idler controller thing and put it back on now my pgm-fi light comes on after it runs for a minute >.<
Old Feb 25, 2010 | 03:06 PM
asdfyellow's Avatar
Any updates?
What do you mean it crapped out on you one day? Did it start up, idle really crappy, then just die? Bc Mine does that too randomly.... My pgm-fi light comes on while driving too.
I'm just following. I've replaced both the alternator and battery like 3 months ago. I will be selling my car shortly.
2ndgenaccord
Classic Hondas
Jan 20, 2013 12:57 PM
RubberGloveBoii
Sep 30, 2011 04:49 AM
louisiana CRX
Dec 1, 2008 05:37 PM
redrexracer
Dec 22, 2006 08:38 AM
