My car wont do nothing....NOTHING
Old Feb 19, 2010 | 02:34 PM
Dipset Racing's Avatar
Default My car wont do nothing....NOTHING
I just recently put my b16 into my hatch and for some reason it wont do anything. it doesn't turn over, the fuel pump doesn't come on, nothing is happening, i turn the key and nothing. help me please. and suggestions on wat i should check.
Old Feb 19, 2010 | 02:44 PM
flash69's Avatar
Default Re: My car wont do nothing....NOTHING
maybe you have a faulty ecu? or you connected the engine wiring harness wrong. Did you make sure you did it right?
Old Feb 19, 2010 | 02:58 PM
nsxter's Avatar
main relay, ignition switch
Old Feb 19, 2010 | 03:08 PM
I knw its not the ecu because it was perfect in the pervious car, but maybe the engine wiring harness is wrong, i will check that, and the main relay, and ignition switch.
Old Feb 19, 2010 | 03:34 PM
shogee's Avatar
check ground connections thats what it sound like
Old Feb 19, 2010 | 03:39 PM
Funanin's Avatar
yea its not the ecu, the car will still crank even with no ecu connected. Try the main relays on ignition and fuel pump, or fuses... do you get any dash lights on when u turn the key or no?
lazylegs15
Sep 14, 2008 10:20 PM
slow hatch
Apr 19, 2004 10:00 AM
xci_ed6
Jan 17, 2004 04:51 PM
Red_Si
13
May 7, 2003 03:21 AM
