battery problem
I have a prob with my battery. The batt reads 12v so its good but wen I try to start my car it doesn't even crank. Wat is it? It will start one time and wen it does start it starts really slow. Its like the power drops a lot. I've had the batt tested by kragen and it checks out good. I can only push start my car. Can anyone point me to where I need wat I need to do? Thanx
The starter ground maybe?I noticed wen I drive it for a while it starts without a push, ill break out my dmm and creck grounds before I buy a starter
i had the same problem. took the starter and had it checked, it passed. took the battery to have it tested, it passed. checked my grounds, all were good. it ended up being my battery. even tho it passed it was bad.
When the battery is tested at the shop they don't test the cranking amps. I checked mine and it was fine. I'm gona see if there is power going to my starter solenoid if not, then I'm suspecting a bad ground.
So I was looking at the starter wiring and I se that the power is directly from the batt. And the ground goes somewhere. Anyone know where I could measure resistance on the ground side? Anyone have a wiring diagram for the starter?
Simple way to test the ground system, jump the car and put the negative jumper on a clean engine bolt. If it starts no problem then it's the ground. If it even cranks a little, just slowly, then the starting system is working up to the starter. Are the battery terminals and cables clean and tight? Also what is the voltage on the battery when it's sitting and when you crank it over?
ZexyAccord
Jan 9, 2006 03:34 PM
