Need help from turbo gods... Werid problem only occouring once boost has been hit...
Old Sep 6, 2002 | 05:58 PM
TurboDragger's Avatar
Default Need help from turbo gods... Werid problem only occouring once boost has been hit...
I need some advice... Once I start up my car, its fine... revs fine and everything. After I get into boost, and say slow down at a stoplight, right at two grand it idles really funny and jerks the car. All I have done recently is put on a new tb... another stock tb. Could it be some ajustment I need to make on the new tb? It only starts jumping and idling funy @ 2k AFTER I have been into boost.. Im baffled.. any help?
EDIT: Just a FYI.. Im running 310's witha 8:1 disk in the FMU, and a inline fuelpump in the way of fuel management.
EDIT 2: I also had replaced the IACV. The IAC motor isnt hooked up, and never has.
[Modified by TurboDragger, 3:25 AM 9/7/2002]
Old Sep 6, 2002 | 07:29 PM
CzanSOHC's Avatar
Default Re: Need help from turbo gods... Werid problem only occouring once boost has been hit... (TurboDragg
hmmm...check for vaccum leaks..
Old Sep 6, 2002 | 09:25 PM
I already have...nope.
[Modified by TurboDragger, 6:26 AM 9/7/2002]
Old Sep 6, 2002 | 11:34 PM
Kamin's Avatar
it sounds like a vacuum leak
i would triplecheck the tb gasket, this way
go take the car out, reproduce the problem
bring it home
let it idle and spray some carb cleaner or somthing to see if it changes the idle.
93cord
Mar 12, 2010 08:28 AM
lowered94accord
20
Dec 18, 2007 08:40 PM
quicksilvia
Jan 27, 2006 07:16 AM
quicksilvia
Jan 27, 2006 07:01 AM
AspectIndustries
May 23, 2005 04:22 AM
