Steering Wheel Swap
I got a steering wheel out of a Honda Prelude that I want to put in my 95 Integra. It doesn't have an airbag but it does have cruise and horn. I wanted to know if there would be any complications with swapping from the airbag to the one without?
Here's a pic of the new wheel:
People run "race" steering wheels all the time with no airbag. Almost all aftermarket wheels are bag-less so you should be fine. Just remember it was your decision to be a DA when you have a wreck and have your forehead smashed on it....
While that is a valid point (expressed sarcastically), do keep in mind that the seatbelts in SRS equipped cars are different than those that came without airbags. They were designed to work together with the SRS bags, and one can never tell how safe they are or aren't once part of the system has been changed (unless one is an engineer who has worked on such things I suppose). I believe that the pre-tensioner might not fire if the SRS system is not fully functioning, for example...
v4lu3s
May 11, 2018 06:36 AM
GReddyTurboCoupe
May 23, 2005 01:44 PM
