What to do: History of my Integra
I bought my 98 LS a little over a year ago, never broke down, currently has 163k miles. I started having overheating issues so I changed the thermostat, water pump and timing belt. After that it was still overheating so I changed the radiator cap, it helped but still had to put antifreeze in once a week. Finally realized a few days ago I need a new radiator because this one is leaking pretty bad.
During the water pump/timing belt install I changed all the gaskets with cheap ones that I got from Ebay, biggest mistake ever, ended up with oil in my spark plugs that I just put on. Cleaned them out, let them dry, everything was fine. Then once in awhile when I would start my car it struggled for a few seconds than began idling normal.
During this time the CEL would go on and off did the paper clip jump and got a code for o2 sensor.
This is over the course of the year, I have a 70 mile commute everyday and never had any problems getting to and from work. The CEL was off for about 3 months then finally it came on again the other day, so yesterday I decided to stop at a garage quick to get the results. It threw a bunch of codes, the o2 sensor, A/T shift solenoid "B", Misfire on cylinder 1, 2, 4. I got the o2 sensor changed while I was there, as I am leaving I got a few miles and I here bang, bang, bang, quick turned off the car and popped the hood.
The spark plug wire was off, so I put it back on and start it back up and this time the spark plug shot out. It looked pretty beat so I went and got new ones, put the new one on and it wasn't getting real tight, I kept trying to start it and nothing, then finally the last time I started it BOOOM, the loudest thing I have ever heard, after about 15sec we hear the spark plug hit a car, looking around everywhere finally my Dad checked the roof of his car and there was a 1/4" hole on the roof from the spark plug hitting it.
The outcome is the spark plug is stripped and my car sits 2 blocks from my house.
So the big question is, given the problems with the car, should I fix it or let it go, I don't know how hard it is to re-thread with a kit and I don't know how the car will run after the spark plug popped out like that. It has 163k miles.
CLIFF NOTES: Spark plug thread is stripped and there are a few other problems with the car, so do I fix it? How hard is it to re-thread with a kit?
Man thats freakin crazy, i never heard of a spark plug shooting out like that I think this is a be issue here. Also you need to be careful not to get any metal shavings into the cylinder when you rethread. Never did this so don't have any advice for you.
I am worried about any damage from the spark plug popping out besides the threading, I dont want to spend money and waste time if it gets done and it still doesnt run right.
alpha honda fan
Apr 30, 2013 02:18 PM
