07 accord(want to install system)
Old Feb 19, 2010 | 02:04 AM
slowcm5accord's Avatar
Default 07 accord(want to install system)
i have an 07 accord, and it has the factory stero.. I also have a converter box for my pre-amp signal and have a way to run power, and have a ground. now all I need is my "remote". What is a good place to tap into for power to turn the amp on? was there a factory amp/sub package on these cars, that there would be a remote in the trunk? i know there is no power antenna seeing that my car has the antenna in the rear window... I dont want to have to rip my entire dash apart just to get a ignition source for the amp Thanks for the help, i greatly appreciate it.
-Zach
Old Feb 19, 2010 | 06:15 PM
1fastvtec's Avatar
Default Re: 07 accord(want to install system)
Find a switchable power source in the fuse panel. I have my amps hooked up in my truck like that because I retained the factory deck, eq, and changer. Good place to start. If you can find a switchable source in the trunk that would def be an easier way to go due to not having to run the extra wire through the car.
slowcm5accord
Feb 19, 2010 11:29 AM
vteckiller
Audio / Security / Video
Jun 28, 2003 04:10 PM
JOMO
Jun 17, 2003 09:22 PM
JOMO
May 7, 2003 07:30 PM
type rizzy
Jul 6, 2002 04:52 PM
