Car antenna missing, buying aftermarket, need help
Old Feb 18, 2010 | 09:51 PM
SRd240sx's Avatar
Default Car antenna missing, buying aftermarket, need help
Hey guys, I bought my 2002 Infiniti G20 Sport with a shaved antenna, so the radio reception isn't great since it's missing the antenna.
Surprisingly I get a few channels when I'm within range, but I would like to install something to get better reception.
I'm not exactly sure what I need but I want to buy something like this:
http://www.amazon.com/Hidden-Antenna.../dp/B001QYSXAS
but it looks it uses this type of cable:
I took a picture of my trunk and I have these two things:
Is there some sort of adapter I can use to make this work?
Old Feb 19, 2010 | 05:46 AM
fcm's Avatar
fcm
Old Fart
Default Re: Car antenna missing, buying aftermarket, need help
You will need the ant. adapter that plugs into the back of the stock HU, [Metra 40-NI21] then you can plug your "hidden antenna" into it.
The one you show is the 40-NI30 that would plug into the stock ant. when changing the HU to aftermarket. 94
Old Feb 19, 2010 | 12:14 PM
SRd240sx's Avatar
Doh that makes sense. And I guess I don't necessarily need to route the antenna all the way to the back, I can probably leave it inside the dash somewhere (though not sure if that will give the most optimal reception). I'll try it out, thanks!
Old Feb 19, 2010 | 01:11 PM
fcm's Avatar
fcm
Old Fart
I have used this one... http://www.scosche.com/products/sfID...productID/1052 on many cars/hotrods with very good results.94
Old Feb 19, 2010 | 10:07 PM
bopbop93030's Avatar
Not to Hijack your Thread, but I have a bad experience with that Hidden antenna you have to find a great location for it to work properly, I tried it in the trunk, bumper, back window.
FCM, Is that antenna can be hidden or this is only can be put in the windshield?
Old Feb 20, 2010 | 07:49 AM
fcm's Avatar
fcm
Old Fart
It is best installed on the windshield or any window, however I have installed them under fiberglass trunk lids and even under dash pads. 94
Old Feb 20, 2010 | 09:42 AM
SRd240sx's Avatar
No thanks for the feedback bopbop! I'll do some more research to see what my best option is. Do you have any recommendations? fcm?
Old Feb 21, 2010 | 06:21 AM
fcm's Avatar
fcm
Old Fart
Sorry no, I have not used the hidden ant., I would move it around to diff. spots before permanently mounting it. 94
Old Feb 24, 2010 | 07:00 PM
SRd240sx's Avatar
Great, going to do more research and try that out, thanks, fcm
MANualBoy
Audio / Security / Video
Jul 3, 2014 09:37 PM
jonyi27
May 27, 2014 08:13 AM
solex
Honda Civic (2001 - 2005)
Oct 1, 2010 05:08 AM
charlieny
Dec 1, 2008 07:44 AM
porkchop14
Sep 29, 2004 01:59 AM
