resistor box?
Old Feb 18, 2010 | 09:01 PM
92 teggy's Avatar
Default resistor box?
i have a 91 ef. it had dpfi in it, i am in the process of dropping a mini-me into it(before you bag on the mini me, my other motor blew and this was given to me, just got done rebuilding it) which has mpfi, i swapped out the ecu and dizzy and all that, but i was wondering if i needed a resistor box for that or not.
Old Feb 18, 2010 | 11:40 PM
spun Vtec's Avatar
Default Re: resistor box?
Yeah you do I have one for sale PM me.
Old Feb 19, 2010 | 12:04 AM
D16SiHatch's Avatar
if you're using obd0 injectors then yes. if obd1 then no
Old Feb 19, 2010 | 07:15 AM
tunerEF9's Avatar
u have to run an injector resister box it has to connect to the injectors for the injectors to run right obo or obd1 doesnt matter and any resistor box will work...
Old Feb 19, 2010 | 11:25 AM
D16SiHatch's Avatar
that is incorrect. obd1/2 injectors are saturated and do NOT use a resistor box.
Old Feb 20, 2010 | 01:59 AM
tunerEF9's Avatar
ive converted a ton of dpfi to mpfi and u must run a resistor box for obo and obd1 in fact my current set up is obd1 and if i had no resistor box my car would not run it sends the proper current to the injectors u must have it
Old Feb 20, 2010 | 02:11 AM
lunalink's Avatar
no u dont. you dont HAVE too have it.
and ther's no such thing as obd0 and obd1/2 injectors.
only low and high inputant ( however it is) injectors
for "obd0" you NEED resistor box
for "obd1/2" you dont need the box- but you can use it IF YOU WANT.
Old Feb 20, 2010 | 08:48 PM
tunerEF9's Avatar
ok if u dont think u need a resistor box for 0bd 1 or 2 then what would u do with the 4 extra injecter wires if u dont hook them up to a resistor box?
Old Feb 20, 2010 | 09:21 PM
CO_RaceFab's Avatar
jump them all together and throw 12v at them. you only need the resistor box to lower the voltage going to low impedance injectors hence the term low impedance or peak and hold. if you dont use the resistore box on obd0 injectors it with fry the ecu eventually there is some good reading about this on www.hondata.com. obd1 injectors aka saturated or high impedance require straight 12v power.
Old Feb 20, 2010 | 10:15 PM
D16SiHatch's Avatar
correct ^
here. learn a thing or two
Old Feb 20, 2010 | 10:55 PM
Icon_Ed6's Avatar
"Originally Posted by tunerEF9
ok if u dont think u need a resistor box for 0bd 1 or 2 then what would u do with the 4 extra injecter wires if u dont hook them up to a resistor box?"
LOL, I thought this was a joke at first. Go pop the hoods on some stock ek's, and eg's n send me the pics of where honda put the "necessary" resistor boxes. Jus cuz YOU put them in doesn't mean they were supposed to be there.
Old Feb 21, 2010 | 09:43 AM
tunerEF9's Avatar
my bad ill admit im the idiot ive always keeped the resistor box thought it was nessacery never had one problem guess i was lucky...
Old Feb 22, 2010 | 08:09 PM
92 teggy's Avatar
ok, so just double checking and making sure this is all coming out right in my mind, since i have put the "obd1/saturated/high impedance" injectors on this motor, i dont need to have the resistor box, correct?
Old Feb 22, 2010 | 08:22 PM
D16SiHatch's Avatar
affirmative
Cap'N Chronic
Aug 30, 2011 02:39 PM
SiR eF_4door
Jul 25, 2009 10:58 AM
immorality
May 24, 2008 03:46 PM
2ndGenREX
Jan 26, 2007 10:12 AM
Lissav
Nov 12, 2005 11:52 PM
