Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Need advice 2002 Acura TL TypeS
Old Feb 18, 2010 | 05:21 PM
laziebun's Avatar
Default Need advice 2002 Acura TL TypeS
So the dealer want 4980 for this car Black on Black body clean and clean car-fax. It has 166,xxx mile and the SRS light is on and the right hub needs replace. What are your guys expertise in this matter. Not to familiar with these TL's Thanks in advance.
http://peoria.craigslist.org/ctd/1605529090.html
Old Feb 18, 2010 | 08:30 PM
slomofo's Avatar
GDD Member
Default Re: Need advice 2002 Acura TL TypeS
I wouldn't buy it due to the high miles, but if it floats your boat, go for it.
The right wheel hub is about $90, you'll need a new bearing which is about $50, and you can install it yourself fairly easily. If you get the knuckle off and can't figure it out, a machine shop would charge you around $15-$20 to press the new hub/bearing in.
I'd have someone check out the SRS issue before committing to buy because that problem might end up costly or cheap. If you don't care about the light and your state's vehicle safety inspection is okay with a non-functional SRS system, then I guess you could skip this portion.
Old Feb 21, 2010 | 05:50 PM
YeuEmMaiMai's Avatar
tell the dealer to fix the car if they want you to buy it at that price. btw run the vin past ur insurance agent. My agent found 2 accidents for my car that carfax did not report.
SRS is most likely OPDS gone bad
Old Feb 21, 2010 | 06:19 PM
laziebun's Avatar
So i bought the car for only 4600. It needed new front brakes and all new tires and front and rear left side hub bearing. The carfax ran up with all schedule maintenance completed at dealer and dealer also installed new tranny 40,000 miles ago. So that what kinda sold me on it. And the **** is CLEAN inside and out!
Old Feb 22, 2010 | 10:06 PM
slomofo's Avatar
GDD Member
Congratulations on your purchase.
DC4R27
Mar 7, 2009 08:43 PM
Crumley
Apr 23, 2007 09:53 PM
mxl36o
Apr 17, 2007 04:59 PM
Spectrum24x
Apr 6, 2006 03:31 PM
AssPenny
Jan 27, 2006 04:54 PM
