Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Help w/ Door Lock Cylinder for 03 Civic Cpe Lx
Old Feb 18, 2010 | 04:51 PM
freeloader88's Avatar
Default Help w/ Door Lock Cylinder for 03 Civic Cpe Lx
Very first post! Yay!
K, this is my issue... I think someone tried to key my car and broke the key cylinder on the driver side. I bought a new set of key cylinder however, I'm stuck trying to get the old cylinder off the door panel. I've taken pics of my mess
Took two bolts off and I still cannot release that latch, seems like the cylinder is holding on to the latch.
So my question is, how the heck do I get that cylinder out!
Pls help?
Old Feb 18, 2010 | 04:56 PM
It Wasn't Me's Avatar
Default Re: Help w/ Door Lock Cylinder for 03 Civic Cpe Lx
There's a retainer clip (looks like a bent piece of coat hanger) tucked behind the bracket that the cylinder mounts to. Have you removed it? You can access it just beneath the cylinder. Pull it down to remove it.
Then just pull the handle up, and out. (like you're opening the door)
Edit: visual aid
Old Feb 18, 2010 | 07:58 PM
Oh snap! Didn't try that, I'll do that and let u know! Thanks so much!
Old Feb 18, 2010 | 10:37 PM
Not a problem. I'm pretty sure that's the only thing keeping it from coming out.
Old Jun 24, 2010 | 06:14 AM
I fanaly got this done around May , I fanaly got it out. The damn pin was so damn hard to put back in!
What sux is that I got the wrong key cylinder! lol
I have a sidewinder key so I have to get the same key cylinder and re-tumble it. Now I have two keys but it will do for now...
Thanks again bro!
***PROBLEM SOLVED***
PS: I actually found a pdf online outlining on how to remove it and how to re-tumble it, if you come across that pdf, please let me know as I can't find it.
Old Jan 16, 2011 | 12:47 PM
Follow up for the above issue -
Like I stated above I was able to remove the cylinder with some dificulty but none the less I was able. I also stated that I had bought the wrong replacement key cylinder which now needs to be "re-tumbled". Please, save yourself 50-100 bucks from the dealership and do it yourself.
Thanks honda.lioness, here is a link to download a PDF that will guide you step by step on how to remove and re-tumble the key cylinder.
http://www.mediafire.com/?c2yzmzdj2xj
The following thread might help you for this similar situation...
https://honda-tech.com/forums/showth...t=key+cylinder
Enjoy!
PS: next one that tries to key my car will be met with a bat to their skull
Old Nov 6, 2012 | 02:23 PM
spflow's Avatar
Icon2 Re: Help w/ Door Lock Cylinder for 03 Civic Cpe Lx
Hey guys, first post here.
So I have 03 Civic and can't get my key in the driver's side lock. This guide looks great but I am having trouble obtaining the parts. I called my local honda dealership and they said that the service has to be done by them because the parts are all scattered and not in a single kit. They'll charge 55 for parts and 150 for labor.
So... where do you get the cylinder kit? I've looked online (ie. here) but I'm not sure what the hell I need. Surely, not the $237 kit.
Can anyone lend a hand? Thanks.
Old Nov 7, 2012 | 11:49 AM
honda.lioness's Avatar
My driver's side door lock also won't accept the key. I have a remote, though.
I fixed it once but it did not last. I am unimpressed by the new design of tumblers on the 2001-2005 Civics. I think a re-build by the dealer or yourself will only last so long.
I have thought of checking to see whether the 1991-1999 Civic's door lock could be fit into the 01-05 Civics. But then the ignition key will not match the door key. And so on. At present I am resigned to living with a non-functioning driver's side door lock.
tmoor
Dec 10, 2011 05:59 AM
sohcjdm
Feb 24, 2010 04:38 PM
cdagza
Oct 26, 2006 03:58 PM
CivicSwapper
Apr 7, 2004 07:33 PM
