Someome please help ASAP!!! Please
Old Feb 18, 2010 | 03:54 PM
ekftw's Avatar
Default Someome please help ASAP!!! Please
Ok so i just bought everything to do a rebuild on my b16a2. A machine shop is gonna put everything together and my question is, I bought JE rings for the pistons. Can i use JE rings on a stock piston? I was told yes, now my tunner said no, before i install these I want to know if it will be okay.
Thanks!
Old Feb 18, 2010 | 05:11 PM
ekftw's Avatar
Default Re: Someome please help ASAP!!! Please
anyone?
Old Feb 18, 2010 | 05:34 PM
93egSLEEPER's Avatar
make sure they are gapped correctly. were they made for forged pistons by any chance?
Old Feb 18, 2010 | 08:56 PM
ekftw's Avatar
Im not sure, I ordered them from a site that just said JE rings for a 81mm b16/b18
Old Feb 18, 2010 | 09:38 PM
Scott_Tucker's Avatar
You need to know what material they are made of and what the recommended surface finish on the cylinder walls is. You will also need to check end gap and as well as side gap and make sure they are within spec.
Old Feb 19, 2010 | 08:41 AM
ekftw's Avatar
Hey guys here a link to the rings I bought.
http://www.summitracing.com/parts/JEP-JG1004-3189
Old Feb 19, 2010 | 10:27 AM
Why did your tuner say no? He must have given you a reason.
Old Feb 19, 2010 | 11:24 AM
H23_del_soul's Avatar
NEED MORE INPUT STEPHANIE!
Made that just for you LOLbuilder FTMFW ya'll
Old Feb 19, 2010 | 12:35 PM
GIZZ - EXV's Avatar
Loved
maybe he ended up overboring and now also need oversized rings?
if still orig pistons and stock bore, the stockers and the JE rings themselves are still 1mm top, 1.2mm mid and 2.8mm oil control rings, should be a-ok.
Old Feb 19, 2010 | 01:15 PM
ekftw's Avatar
Not motor work has been done yet, I just gave him a run down of what will be done to the motor and mentioned stock piston with the ring i posted a link to. And he said usually you still with the same brand but I decided to go with je instead of honda. Someone?
Old Feb 19, 2010 | 01:16 PM
ekftw's Avatar
According to the rings i ordered they are indeed 1mm, 1.2mm, and 2.8mm for oil. So with the stock piston and those rings it will be okay correct?
Thank you so much!
ekftw
Feb 18, 2010 05:14 PM
DC4 Rasta
Jan 5, 2007 06:44 PM
arsenaldragster
Jun 16, 2003 10:01 AM
genop
Sep 18, 2002 03:34 PM
