CRX Dual Exhaust Set up question
Old Feb 18, 2010 | 11:42 AM
BarcodeCRXSI's Avatar
Icon2 CRX Dual Exhaust Set up question
Long time lurker, first time poster here.
I have a 1988 Honda CRX Si with a b16a2 motor I put in not too long ago. I'm currently working on the exhaust system. I'm planning on using all stainless steel for it.
I have the header that feeds into one pipe, then into a high flow catalytic converter, then feeding into a Y pipe. I am asking for any tips or ideas for this setup after the Y pipe. I want to do a dual exhaust set up, but I'm concerned about backpressure and the correct bends and angles I need to do to achieve this.
Any thoughts, or ideas? Thanks in advance!
Old Feb 18, 2010 | 12:01 PM
Sikocivic's Avatar
Default Re: CRX Dual Exhaust Set up question
Put on your flame suit, here we go..............
Old Feb 18, 2010 | 12:10 PM
Radim's Avatar
90degree bends after the y-pipe that dump down.... Old School Musclecar status.
Old Feb 18, 2010 | 12:35 PM
CRX Toad's Avatar
Looks ridiculous. Please reconsider your process. The exhaust will weigh more than the motor at that point.
Old Feb 18, 2010 | 12:37 PM
4drEF's Avatar
Keyboard Humorist
Why? It's not going to be dual exhaust really anyway.
You already are combining exhaust after the header so basically it seems like your dual exhaust is more like 'dual exit' or 'dual tip'.
I don't even think there is going to be a backpressure issue since you are single exhaust all the way through the catalytic converter and then back to the fuel tank area.
Old Feb 18, 2010 | 12:38 PM
DVS_SI's Avatar
please don't
Old Feb 18, 2010 | 12:45 PM
That's essentially what I'm doing, pretty much setting up a dual tip. One exit on each side. I could do the original look with the dual tip on the driver side after the muffler.
Old Feb 18, 2010 | 12:52 PM
Deetz's Avatar
Crazy Honda Guy
With the added weight, money spent on more parts, and zero performance and it looking goofy......i do not see the point!
DON'T DO IT
IemSpooled219
Sep 1, 2012 05:25 PM
GettingOut
Welding / Fabrication
Aug 16, 2011 05:49 PM
2k.civic.si
Nov 10, 2010 08:36 AM
greasemonky50
16
Jan 21, 2006 06:28 AM
