B20vtec build: advice needed
I’m working on my first full motor build so I’m looking for comments, suggestions, and advice. Its going to be a DD motor so I’m more concerned with torque and the midrange power. I am a student so I want to keep this build as budget minded without sacrificing reliability. Here’s what I have so far:
B20 block
RS machine ITR pistons
Shotpeened rods with arp rod bolts
Golden Eagle Vtec kit
GSR head
Street port and polish
Rosko fuel rail with rdx injectors
Arp head studs
Skunk2 Stage 2 camshafts
Supertech or blox dual valve springs
AEM cam gears
68mm throttle body
DC 4-1 header
Tuned with s300
Im only looking to rev to 8500 maybe 9000 tops depending on where peak hp is so im trying to stay away from Ti retainers if possible to get a longer life out of the retainers. I have heard of people using cromoly retainers but I can’t seem to find anywhere to get them. Anyone know what companies have them and where they can be purchased?
Also I am not sure what to do about an intake manifold. What do you guys think would be best for me? Port and polish the short one or get an skunk2 manifold or one from another company?
Also in regards to blox equipment I realized that a lot of their stuff is cheaper than a lot of other companies, is the quality/reliability not up to the level of skunk2 and other companies?
Thanx for any help in advance
B20 block
GSR head
Arp head studs
AEM cam gears
68mm throttle body
DC 4-1 header
Tuned with s300
Im always very iffy about the cheaper brands.Some Blox products have had questionable performance, so id lean to Skunks products instead...Thats just me though.
The 68mm throttlebody gains may be minimal, might drop this item if you want to trim the budget a little. Or try Maxbore. $100 and he reworks your factory one. I just havent ever seen any significant gains from throttle body upgrades...
As far as intake manifolds go, the PerformerX is said to give good midrange due to the long runners...
to me blox is just as good same with omni to be honest there are lots of other product from other companies thats just as good and are cheaper then skunk heck they all made in china and taiwan anyway lol i have seen people say skunk products are junk but its personal prefrence skunk is a lil over priced to me but i guess they can do that because they have been around longer and the name is more known
What about a stock retainer? I'm running stock retainers to 8700rpm. I do have lighter valves and my rocker arms have had weight reduction done to them.
As for the IM, I run the Performer X, very nice piece I strongly recommend it.
Only way to know for sure is to dyno test them back to back...
if your going to run a larger TB i would have it port matched to the manifold to make it worth the money you put at it. bolt on power wise IMO not worth it. portmatched and bored, worth it
I am also i huge believer in Blox products. I have run numerous parts of theirs and always had good luck and performance from them.
I would get Crower cromoly retainers, they are $65 on amazon. (horsepowerfreaks sells them)
In my opinion, vteckidd header is very good one for the money. I have it and like it very much, also it is very durable construction and I have no issues at all for a year now.
If you are going to run this engine for longer than a year (two at the very max), I would get Toda valve springs. If you are going to open head up and replace valve springs more often, maybe some of those other valve sprongs are OK. Also Supertech VS have a very high installed seat pressure and they task your timing belt quite a bit, Skunk 2 pro series springs claim to be low pressure, and good quality, but I do not know if this is true or not.
Toda on the other hand is safe bet, you get what you pay for...
Nino
Nino
Nope sorry. SMSP, no clearance issue to the AC or PS.
There is a lot of discussion about the vteckidd headers right now.
I ran a DC Sports 4-1 header to 184whp. This header in the past has been on cars that made around 200whp. You may not need that new header just yet.
B20 block
RS machine ITR pistons -- good choice
GSR head
Rosko fuel rail with rdx injectors -- use a stock fuel rail. no need for anything else. or is this rail for something besides a higher flow rate?
Arp head studs
Skunk2 Stage 2 camshafts -- thought about Pro series cams? They'll give you more midrange.
Supertech or blox dual valve springs -- If you go with Skunk2 cams (and are buying NEW) use the same brand all the way around with the valvetrain. It just helps if you have issues anywhere
AEM cam gears -- if you must...not crazy about them
68mm throttle body -- Max-Bore does good work on throttle bodies
DC 4-1 header -- A COMPLETE PIECE OF SH*T compared to some of the relatively inexpensive options out there that will DESTROY the performance of a DC
Tuned with s300 good choice
The Rosko fuel rail is so that i can use the RDX injectors without having to modify the tap on the injectors...makes them a direct bolt on minus the plug adapters.
I was originally thinking about using the Pro 1+ but then i wasnt sure about the idle and suck since it is going in my daily driver. do u think with this setup i would be able to run the Pro 1s with cromoly retainers without any problems? I also thought it put more wear and tear on the valve train in general but i could be completely off with this thought.
I would go with the complete Skunk2 but its got a pretty big price tag and i was able to find the supertech components on sale so thats y im considering getting those.
any reason y you dont like the aem cam gears? wat would u recommend? any reason y these are like half the price of the skunk2?
I would try and borrow a friends throttle body and test it out on the dyno. Shouldnt take too long to swap out. I just think the cost of a bigger throttle body ($200-$300?) isnt going to provide good power gains. They do seem to give you better throttle response in my experience...
I had the big tube tri-y, I absolutely loved it on my B18c.
how much power do you want to make? Heres my setup and maybe you can get an idea because i just finished with my build like last week..
b16 slightly ported head
hot tanked, resurfaced, and valve adjustment
blox type b cams
supertech dual valve springs and titanium retainers
aem cam gears
bmw 330 injectors
b18 bored out to 84.5 mm resurface, rehoned and decked
sleeved block
11.5:1 wiseco forged piston
eagle rods
jdm itr headers
itr manifold
itr tb
itr water/oil pump
itr timing belt
arp head studs
2.5 magnaflow cat
i tuned with p28 chrome and a full 2.5 ws2 exhaust because like you, i am a college student and it is my DD. I also replaced all these other lil junk like cam seals, valve stem seal, etc.
My goal was to have a reliable ls vtec build and able to beat rsx ! I spent roughly 2000ish that included like illegal smog, registration, tuning, and labor.
I made my setup conservative because i dont want to get harassed by cops. My bay looks really stock with even a stock itr intake.
Rev limit is still at like 8000. I start losing power at 8200 because of my exhaust, but with the right parts i can easily go to 9000.
The motor has a lot more potential than i am pushing it. If i went with some better headers bisimoto, or hytech, a victor x manifold, test pipe, greddy exhaust, and bigger tb. i can easily make 225-230.
on 91 octane i get roughly 250+ miles
and fyi. lose those dc headers for sure.
My future plans is just get a cut off so i have control of when i want to go open headers to get a lil more power, but other than that whats under my hood is doneeee.. just gotta work on cosmetic cuz exterior looks like crap..
I think you should be more specific about ur budget, how much power u want to make, how much are u willing to risk, (cop wise) etc. I didnt sleeve my block it came with the block which i got for free from a friend. I wouldnt have done sleeve because im not beating the motor all day, but that made me upgrade the pistons because i didnt want to ruin the cylinder wall.. i had some arias 10.5:1 pistons that i decide to take out. There are a million routes man, take your pick and have your fun. Good Luck.!
blox type b cams
aem cam gears
bmw 330 injectors
sleeved block
eagle rods
jdm itr headers
itr manifold
itr tb
itr water/oil pump
itr timing belt
arp head studs
2.5 magnaflow cat
How much power are you makin with that setup? and as far as number for my build id be happy with around 230 whp and 140tq but the numbers arent super important to me. im just looking for a fun car to drive with some decent power. copwise they never look under the hood by me so its not really an issue and as far as the budget im planning on starting to assemble everything at the end of the semester when i go home. when i said budget i meant more like i dont need the best of the best. just spending my money smart and not on useless items.
p.s. im also runnin the ws2 exhaust
