help on timing
Old Feb 18, 2010 | 12:23 AM
n0y's Avatar
n0y
Default help on timing
i have a jdm gsr block wit a type oil pump and was wonder which lower timing belt cover to use obdII or obdI...cause i have heard something about if u are using a itr oil pump u need to use a obdII lower timing belt cover becuase of how the lower timing belt cover is shaped...so which one do i use...obdII or obdI????
Old Feb 18, 2010 | 12:27 AM
K7-1Ktrevor's Avatar
Loved
Community Favorite
Default Re: help on timing
the obd1 wont fit right but will still sorta work if its all you have. go with the obd2 though
Old Feb 18, 2010 | 12:29 AM
n0y's Avatar
n0y
thanks alot man...need to get this done so i could do my timing...
Old Feb 18, 2010 | 01:19 AM
Loved
Community Favorite
no problem. they will both time the motor no problem, just one kinda fits like crap, I ran a obd1 cover on a obd2 ls motor with no issues.
boosted k20
Oct 16, 2017 11:11 PM
NA JDM GSR
Aug 1, 2010 09:17 AM
arrojj
Dec 28, 2006 07:20 AM
85mm LS VTEC
Aug 4, 2004 02:18 PM
