Problems with cluster EG6
Old Feb 17, 2010 | 08:43 PM
rquint07x's Avatar
Default Problems with cluster EG6
Hello fellas
I need someone with experience in this kind of problem that can help me out with my issue
I friend brought me from japan a jdm eg6 cluster (not SiR), the problem is that the oil light does not turn on at the ignition time and the light of needle on the temperature does not turn on at night.
Supposedly the plugs are plug and play but those lights are not working, and we all know how important its the oil indicator. Any suggestions???? JDM Plugs are different from USDM plugs?
When i saw that they are not working I put back the USDM cluster and they work correctly.
Thanks in advance!!!!
Old Feb 17, 2010 | 08:45 PM
egsleepercivic's Avatar
Default Re: Problems with cluster EG6
check bulbs, you can swap the ones over from your original to test
gl
Old Feb 17, 2010 | 08:47 PM
rquint07x's Avatar
Thanks my friend!!!! I forgot to say that i replaced the bulbs but my problem continues
Old Feb 18, 2010 | 04:56 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
You have replaced the bulbs with KNOWN good ones? Hmm, well then there is only a few things it can be, then. Do you have a multimeter tester? Check the connection on the circuit board on the back of the cluster between the oil light pin and the bulb. Also check the connection between the other side of the bulb and the ground pin. Do the same for any other bulbs that are causing a problem. I suspect that it's related. Basically, I'm telling you to test the circuit board to make sure there aren't any breaks in it. Hmm, Is it possible something was damaged during transit? Good luck! Post back with your findings.
Old Feb 18, 2010 | 05:30 PM
rquint07x's Avatar
I really appreciate your suggestion DeSchlong, thank you very much!!!!
I will check the cluster with a tester, also i will post all findings
tofu1413
Jan 28, 2011 08:54 PM
kcrxxx
Apr 2, 2008 08:13 PM
American.Graffiti
Aug 27, 2005 07:53 PM
jdmoutkast
13
Jun 30, 2004 11:50 PM
spoon-eg
Sep 4, 2002 06:29 PM
