S80 Trans - LS or GSR???
Old Feb 17, 2010 | 07:41 PM
teamasr1's Avatar
Default S80 Trans - LS or GSR???
I have a S80 Trans, cant tell if it is a LS or GSR. Want to buy a OBX LSD and need to know which one to buy. Will the GSR LSD work if the tranny is a LS?
Number is: S80 2006073
Old Feb 17, 2010 | 08:36 PM
TheAsian's Avatar
Default Re: S80 Trans - LS or GSR???
Yes the diff from a LS will work w/ the GSR counter shaft. All you need to do is swap the ring gear around the diff and your golden.
Old Feb 18, 2010 | 09:57 AM
teamasr1's Avatar
Tranny has no 'bar' you can see through the axel hole, does that mean it has LSD?
Old Feb 18, 2010 | 10:22 AM
Turbodude06's Avatar
Usually Yes.... Take a picture cause you may already have LSD in that case it could be an ITR trans....
Old Feb 18, 2010 | 10:49 AM
hmoobhero's Avatar
if you can see thru the axle hole than it has lsd. also, obx lsd is not good. has problems with it unless you do something to it...i forgot what it was.
if its the original lsd tranny then it should have lsd stamped on it.
Old Feb 18, 2010 | 12:31 PM
TheAsian's Avatar
You never know though. My trans I broke the clutch housing so I have a GSR Clutch housing on it.
If you can see through the axel shaft hole then yes it is prolly a LSD. Only way to find out what LSD you have is pull the trans apart and check the diff casting ID
TravisBiggie
Jun 13, 2013 06:27 AM
sixfourkiller
May 23, 2009 07:29 AM
DJNauTicz
32
Oct 16, 2007 10:03 AM
AlienKrOZ
Aug 23, 2004 10:30 PM
1996GsrVtec
Jan 16, 2002 11:18 AM
