have a few trouble codes cannot figure it out plz help!
Old Feb 17, 2010 | 07:13 PM
01integB18's Avatar
New User
Default have a few trouble codes cannot figure it out plz help!
I'm gettin 6 codes the firsr 4 are cylinder misfires the 5th is random or mulitple misfire the 6th is a p1399 can't firgure wut it is
Old Feb 17, 2010 | 07:21 PM
GagnarTheUnruly's Avatar
Default Re: have a few trouble codes cannot figure it out plz help!
Not sure but I googled and it seems like another misfire code.
Old Feb 17, 2010 | 07:55 PM
mrdeadman's Avatar
They let me pick
https://honda-tech.com/forums/acura-integra-6/ecu-abs-codes-here-978933/
Re-pull the code.
Old Feb 17, 2010 | 08:34 PM
TheAsian's Avatar
Check your cat. Multiple random missfire is generally caused by a gasket leak bad ign coil or clogged up cat.
I would get the cat see if its clogged up. Check your spark and make sure your good and toasty on that and spary some starting fluid around the intake mani to see if you have any intake gasket leaks. Ill figure out what the p1399 for ya later
galeano
Mar 26, 2005 05:32 AM
Flux
Jan 29, 2005 11:22 AM
R-Rated
May 20, 2002 11:48 AM
stRtypR25
Mar 2, 2002 06:48 PM
EJK
Nov 14, 2001 01:34 AM
