My first build ever: 92 eg hatch
Old Feb 17, 2010 | 06:47 PM
H.I CTR's Avatar
Default My first build ever: 92 eg hatch
This will NOT be one of those baller build threads such as B16b_coupe, vietjdmboi, Chef Andre, BaconLettuceTomato or anyone else like that for that matter. Well being 17 with no job this will be a SUPER LONG term project. This is the first car I have ever owned. I purchased my EG back in APRIL 09' completely bone stock. It was my beater for a few months till I got my four door EK. Reason why I got another car was due to the motor will be needing a rebuild soon and having a little ADHD I needed a project. My goal for this build is to restore the whole car ground up, with some upgrades as well. The hatch is going to stay the same color because I like my things OEM and I like the color. I will try to update this thread as much as possible, so bear with me.
when I first got it...
then put on some drop springs
couple pics before I started taking it apart
I have most of the interior stripped already, waiting for my friend to come by and help me pull the motor..here is a couple pics of how it sits currently
SWAP PARTS
ENGINE/TRANNY
[x] K-series engine(K24/K20)K20Z3
[x] K-series tranny(Type-R/RSX-S/RSX Base)
[] K-series engine harness(RSX-S 02-04)
[] K-series charging harness(RSX-S 02-04)
[x] K-series Alternator
[x] K-series Starter
[] K-series ECU(RSX PRB 02-04) Plus Hondata K-Pro
[] RSX Type-S Oxygen Sensor(Primary)
[] RSX Type-S Knock Sensor(Only if not using RSX-S engine, Or repin stock Knock sensor)
[x] RSX Type-S Throttle Body w/ sensors
[] Karcepts Throttle Body Adapter
[x] Engine Mounts
[x] Harness Conversion
[] Clutch Line
RADIATOR/COOLING
[] Fluidyne 92-95 Civic
[] Hybrid Radiator Hose Adapter
[] Spal Slim Fan
[] TOP Rad Hose
[] BOTTOM Rad Hose
[] B/D Series Thermo Switch and Temp sensor
[] Radiator top mount
SHIFTER PARTS
[] Hybrid Racing K Swap Bolt-In Short Shifter
[] RSX-S 02-04 Shifter Cables
[] Shift Parts to Connect Cables
[] RSX-S Shift Arm
EXHAUST PARTS
[] Buddy Club Spec II for 92-95 EG Hatch Civic 2.5"
[] Header (R-crew) 2.5" Collector
FUEL SYSTEM PARTS
[] Fuel Rail
[x] Fuel Lines
[] Fuel Pressure Regulator
[] Regulator Mount
Old Feb 17, 2010 | 07:01 PM
josh-roy's Avatar
Default Re: My first build ever: 92 eg hatch
Looks pretty clean man, take your time and enjoy it.
Old Feb 18, 2010 | 05:51 AM
ken9's Avatar
Look alright
Old Feb 18, 2010 | 05:22 PM
ryans97ek's Avatar
What are some of your plans for it?
Old Feb 18, 2010 | 05:26 PM
DrZFiNeSt's Avatar
Looks like your off in the right direction
Old Feb 18, 2010 | 09:40 PM
H.I CTR's Avatar
possible k series and 5 lug? also color change? maybe some vsm? all depends on the funds.
Old Feb 18, 2010 | 09:41 PM
H.I CTR's Avatar
thanks
Old Feb 19, 2010 | 10:47 AM
Kyle R's Avatar
Old Feb 20, 2010 | 01:14 PM
H.I CTR's Avatar
^^^thanks
Old Feb 20, 2010 | 02:08 PM
hondaEg_808's Avatar
bummp for HI!! which island are you on bro?! im oahu!
Old Feb 21, 2010 | 09:41 PM
H.I CTR's Avatar
im on the big island
Old Mar 9, 2010 | 09:51 PM
H.I CTR's Avatar
ok..im stuck on deciding with what color im going to go with..either the original color or spray it the tundra brown.
Old Mar 10, 2010 | 10:21 AM
milkmanLCA's Avatar
keep it originale!
use that money on other goods
Old Mar 10, 2010 | 09:32 PM
rareEK9's Avatar
yup keep it original color.. mr. blownupdat1..hahahah..
Old Mar 13, 2010 | 11:42 AM
H.I CTR's Avatar
haha..hopefully pulling the motor soon
Old Mar 30, 2010 | 03:38 PM
rareEK9's Avatar
any updated pics? how's this project coming along?
Old Mar 30, 2010 | 07:24 PM
SHG_James's Avatar
wow, the body looks perfect. original paint?
Old Mar 30, 2010 | 10:33 PM
H.I CTR's Avatar
negative..the car was painted previously but it is still the original color
Old Mar 30, 2010 | 10:34 PM
H.I CTR's Avatar
yup. ill upload um soon. haha the motor was out for a while already
Old Mar 30, 2010 | 11:16 PM
H.I CTR's Avatar
During the spring break my friends came over to help me pull the motor. Also i waited about a 2 weeks for my suspension and it didnt show.Well the next day I checked the post office and it was there for about a week! LOL so I got that installed on my 4 door. Well enough talk heres the pics.
HEARTLESS
POS B7
HMMMM WHATS THIS?
MY SUSPENSION!
installed
and polished the exhaust
Old Mar 30, 2010 | 11:25 PM
prelude182's Avatar
im in for this build and good luck
Old Mar 31, 2010 | 12:07 AM
H.I CTR's Avatar
thanks!
Old Mar 31, 2010 | 04:51 AM
ken9's Avatar
Window tint always look good on civic...
Old Mar 31, 2010 | 10:11 AM
skylinerb26dett's Avatar
did you do any adjusting on the type ones? or is that how it came out the box? because i bought these for my 96 hatch and i was just wondering!!
Old Mar 31, 2010 | 11:39 PM
H.I CTR's Avatar
suspension was put on straight out of the box
