My first build ever: 92 eg hatch
This will NOT be one of those baller build threads such as B16b_coupe, vietjdmboi, Chef Andre, BaconLettuceTomato or anyone else like that for that matter. Well being 17 with no job this will be a SUPER LONG term project. This is the first car I have ever owned. I purchased my EG back in APRIL 09' completely bone stock. It was my beater for a few months till I got my four door EK. Reason why I got another car was due to the motor will be needing a rebuild soon and having a little ADHD I needed a project. My goal for this build is to restore the whole car ground up, with some upgrades as well. The hatch is going to stay the same color because I like my things OEM and I like the color. I will try to update this thread as much as possible, so bear with me.
when I first got it...
then put on some drop springs
couple pics before I started taking it apart
I have most of the interior stripped already, waiting for my friend to come by and help me pull the motor..here is a couple pics of how it sits currently
SWAP PARTS
ENGINE/TRANNY
[x] K-series engine(K24/K20)K20Z3
[x] K-series tranny(Type-R/RSX-S/RSX Base)
[] K-series engine harness(RSX-S 02-04)
[] K-series charging harness(RSX-S 02-04)
[x] K-series Alternator
[x] K-series Starter
[] K-series ECU(RSX PRB 02-04) Plus Hondata K-Pro
[] RSX Type-S Oxygen Sensor(Primary)
[] RSX Type-S Knock Sensor(Only if not using RSX-S engine, Or repin stock Knock sensor)
[x] RSX Type-S Throttle Body w/ sensors
[] Karcepts Throttle Body Adapter
[x] Engine Mounts
[x] Harness Conversion
[] Clutch Line
RADIATOR/COOLING
[] Fluidyne 92-95 Civic
[] Hybrid Radiator Hose Adapter
[] Spal Slim Fan
[] TOP Rad Hose
[] BOTTOM Rad Hose
[] B/D Series Thermo Switch and Temp sensor
[] Radiator top mount
SHIFTER PARTS
[] Hybrid Racing K Swap Bolt-In Short Shifter
[] RSX-S 02-04 Shifter Cables
[] Shift Parts to Connect Cables
[] RSX-S Shift Arm
EXHAUST PARTS
[] Buddy Club Spec II for 92-95 EG Hatch Civic 2.5"
[] Header (R-crew) 2.5" Collector
FUEL SYSTEM PARTS
[] Fuel Rail
[x] Fuel Lines
[] Fuel Pressure Regulator
[] Regulator Mount
SWAP PARTS
ENGINE/TRANNY
[x] Engine Mounts
[] Clutch Line
RADIATOR/COOLING
[] Spal Slim Fan
[] TOP Rad Hose
[] BOTTOM Rad Hose
SHIFTER PARTS
[] RSX-S Shift Arm
EXHAUST PARTS
FUEL SYSTEM PARTS
[] Fuel Rail
[x] Fuel Lines
[] Regulator Mount
Re: My first build ever: 92 eg hatch
ok..im stuck on deciding with what color im going to go with..either the original color or spray it the tundra brown.
During the spring break my friends came over to help me pull the motor. Also i waited about a 2 weeks for my suspension and it didnt show.Well the next day I checked the post office and it was there for about a week! LOL so I got that installed on my 4 door. Well enough talk heres the pics.
HEARTLESS
POS B7
HMMMM WHATS THIS?
MY SUSPENSION!
installed
and polished the exhaust
HEARTLESS
POS B7
HMMMM WHATS THIS?
MY SUSPENSION!
installed
did you do any adjusting on the type ones? or is that how it came out the box? because i bought these for my 96 hatch and i was just wondering!!
