ECU code question
Old Sep 6, 2002 | 03:12 PM
Timmah!!'s Avatar
Default ECU code question
The speedo does not work in my CRX, so naturally it will throw a code 17
but recently it seems to be throwing out 2 code 1s
The ecu will blink once, pause, blink again, pause, then blink seventeen times. and repeats
why would it throw out the code 1 twice in a row??
[Modified by azroth, 7:12 PM 9/6/2002]
Old Sep 6, 2002 | 04:52 PM
USDM 4G VTEC's Avatar
Default Re: ECU code question (azroth)
how do u know that the O2 sensor its not bad
code 1 its oxygen content......
make sure ur O2 its within specs... reset ecu and see if they still there......
Old Sep 6, 2002 | 04:54 PM
Jared's Avatar
Is it possible you're seeing code two and 17? What engine/ecm are you using?
Old Sep 9, 2002 | 11:29 AM
Timmah!!'s Avatar
Default Re: ECU code question (Jared)
I am using a 89 crx Si ecu... There is NO code 2 i am sure it was flashing 2 code ones... I thought it might be a code "two" but there is too much of a gap in between flashes... I Changed the FPR And the EICV, and the code is gone... But there is still one sensor on the Intake manifold that did not match up with the HF wireing harness it is on the bottom, right of the intake, and it is NOT the intake temp sensor. I still dont know why it was flasing two of the same code. I just have not seen that before.
doom26464
Aug 26, 2008 07:45 PM
drewboy
May 14, 2005 10:03 PM
Jeef
Dec 9, 2001 06:35 PM
delsol93
Jun 21, 2001 02:54 PM
