high idle on my b20vtec turbo help please
ok my b20 is idleing high the cel is not but i decided to check it anyways it brought up the tps sensor so does anyone know where i can get a new one and how do i check the wires to make sure its fine?
Get a voltmeter and measure the 3 wires at the tps sensor. Back probe them gently. One should be ground, one 5 volts, and the other .5v at closed throttle, 4.5ish at WOT.
High idle could be from a sticking throttlebody too. Also try cleaning out all the gunk inside your IAC motor and check you base timing.. If after that, you still have a high idle, look for a vacuum leak. Good luck!
I think Omniman/Omnipower sells them for like $70.
Not sure if theyre any good or not as Ive never used any omnipower products before.
I believe theyre only available from the dealership with the whole throttlebody so that means $$$$. Good luck!
slowB20ej8
Jan 3, 2008 09:42 PM
