zc dizzy
Old Feb 17, 2010 | 05:31 PM
miggy23's Avatar
Default zc dizzy
i was just wondering what distributor can i use on a singe cam zc engine i know i can't use my dpfi dizzy so which ones can i use please help!!!!
Old Feb 18, 2010 | 04:31 AM
Sikocivic's Avatar
Default Re: zc dizzy
The one from the D16a6 will work.
Old Feb 18, 2010 | 04:58 AM
90SICRX's Avatar
X2
Old Feb 18, 2010 | 01:41 PM
miggy23's Avatar
any where cheap i can get one every one wants over 150 for there dizzy
Old Feb 18, 2010 | 05:40 PM
miggy23's Avatar
will any d16 harness work with this set up or does it have to be a d16a6 harness of a civic si
Old Feb 18, 2010 | 05:55 PM
BiG ChOr!Zo's Avatar
use your existing harness and convert to mpfi...save yourself the money of buying another wire harness...!!!
Old Feb 18, 2010 | 06:05 PM
miggy23's Avatar
i just found 1 for 40 bucks on craigslist but how can i tell the diffrence between an si and dpfi harness and obd 0 , obd1 and obd 2 because i know i need an obd 0 to run a pm6
Old Feb 18, 2010 | 07:37 PM
here's your resistor box...!!!
http://inlandempire.craigslist.org/pts/1607484309.html
Old Feb 18, 2010 | 09:17 PM
miggy23's Avatar
so the da one will work on the zc engine or it doesnt matter
Old Feb 18, 2010 | 09:19 PM
it works just fine...offer the guy $10 and call it a day since he has posted that same ad up forever...!!!
Old Feb 19, 2010 | 05:12 AM
Sikocivic's Avatar
If you car is a DX with DPFI you have to use that harness and modify it to MPFI(read to FAQ at the top of the page). If you try to use a MPFI harness it won't plug in to your chassis harness. It is alot less work to convert your old DX harness then to replace the engine and chassis harness.
Old Feb 19, 2010 | 07:11 AM
miggy23's Avatar
so it won't work just with the engine harness I need the chassis harness as well I thought it would just plug right in
Old Feb 19, 2010 | 12:03 PM
Sikocivic's Avatar
Just do the DPFI to MPFI
There are a couple of "how to" in the FAQ. READ THEM
Old Feb 19, 2010 | 12:14 PM
DCRB's Avatar
OMG mpfi swap is EASY!! you move two wires at the ecu and run four more to the engine bay, remove one plug and adapt the mpfi injector clips to your existing harness. super easy. search for a good wright up.
Old Feb 20, 2010 | 07:33 AM
miggy23's Avatar
alright cool thanks
Old Feb 20, 2010 | 07:47 AM
jlicrx's Avatar
DPFI to MPFI:
http://www.fourthgenhatch.net/mpfi.html
Redemption
Sep 25, 2009 09:48 AM
pec pec
Jan 26, 2006 06:49 AM
D3U1LT
Jun 27, 2005 01:18 PM
Dspad_91Civic
May 7, 2004 05:12 PM
zccrx
Mar 23, 2003 02:50 PM
