Dual valve springs with oem retainers
Old Feb 17, 2010 | 02:50 PM
gutted-dx's Avatar
Icon2 Dual valve springs with oem retainers
How is using aftermarket valve springs with Oem retainers? I'm only going to be running ITR cams at the most, just don't really like TI retainers, and they won't really make a difference cause my redline will be set at 8000 tops. I've looked for ITR springs with out luck, and also just another set of GSR intake springs with no luck. Someone point me in the right direction, thanks.
Old Feb 17, 2010 | 03:35 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: Dual valve springs with oem retainers
You can run 2002-2004 RSX type-s retainers and use your current keepers. They are CrMoV. I run them with supertech springs and Blox C cams.
Old Feb 17, 2010 | 04:42 PM
all-mtr-teg's Avatar
Are those flat or dish style retainers? If I recall, I read somewhere that there are 2 styles and one gives more clearance.
Old Feb 17, 2010 | 05:18 PM
mar778c's Avatar
Community Builder
The 02 retainers are flat. The 06 retainers are dished.
Old Feb 18, 2010 | 12:22 PM
igorka_91's Avatar
My TI retainers look beetup. Theyre in an b16 head and will be a daily driven car. What year shuld i get the RSX-S retainers from to fit onto an b16 head. The 06 or the 02-04......?
Thanks
Old Feb 18, 2010 | 12:23 PM
gutted-dx's Avatar
mar I'm looking to keep my stock retainers and looking for aftermarkets springs. I think might have worded it wrong.
Old Feb 18, 2010 | 06:40 PM
mar778c's Avatar
Community Builder
Thanks
Old Feb 18, 2010 | 06:45 PM
mar778c's Avatar
Community Builder
I understood your 1st post. You can run them but I would not recommend it. Supertechs are significantly stiffer than OEM and the fit between the spring and the retainer is not exact. Depending upon the condition of your current retainer, you could experience a lot of wear very quickly. When you change springs it is best to change the retainer.
Old Feb 18, 2010 | 07:42 PM
igorka_91's Avatar
Thanks mar778c..I gues i kinda spaced out.
Old Feb 18, 2010 | 11:14 PM
negusjuda's Avatar
im running portflow springs with type r retainers but im only running a stage 1 cam
Old Feb 19, 2010 | 02:18 PM
igorka_91's Avatar
Ok so i just talked to an Acurs parts sales man. The 02-04 rsx-s retainers are about $5.30 a pop wich will be around $92 with tax for 16 of them.
What year retainers shuld i order. Like stated above. Some give more clearance. This will be in an b20vtec with 12.5:1 CR and an PNP b16 head with dual valve springs, supertech flat face valves. Will run it on CTR cams for a lil while then save up for some Stage 2 cams.
Thanks
Sorry to tread jack youre tread gutted-dx
Old Feb 19, 2010 | 03:20 PM
00Red_SiR's Avatar
All Motor Mentor
Again, as already mentioned previously, you want 02-04 retainers.
Old Feb 19, 2010 | 04:57 PM
hondamn1320's Avatar
acura automotive parts gives 2 part numbers for the retainers.
14765-PRB-A00 RETAINER, VALVE SPRING 016 2002 RSX 3.09 2.32
14765-PRB-A01 RETAINER, VALVE SPRING 016 2002 RSX 3.00 2.25
Is there a major difference between the intake and exhaust retainer?
Old Feb 19, 2010 | 05:00 PM
Lortt's Avatar
Thanks
You could probably get those for cheaper, check out a few genuine acura parts websites first.. heres what i found real quick http://www.acuraoemparts.com/delray/...All&vinsrch=no
The part#14765-PRB-A00 is just $2.32 a piece there
Old Feb 19, 2010 | 05:03 PM
Lortt's Avatar
A quick search of 14765-PRB-A00 in google and theres three links near the top stating these are the flat ones, and the A01s are dished.
Old Feb 19, 2010 | 05:43 PM
igorka_91's Avatar
Well there are two options. The dished ones and the flat ones. Wich are better for an all motor build
Thanks
I was at work so couldnt really search it.
Thanks
Old Feb 19, 2010 | 06:25 PM
092eg6's Avatar
curious to find out too!!
Old Feb 19, 2010 | 07:10 PM
mar778c's Avatar
Community Builder
Guys, you should use the flat ones. The part number is 14765-PRB-A00.
Hopefully that clarifies for everyone.
Old Feb 19, 2010 | 07:30 PM
Does for me.
Old Feb 19, 2010 | 10:28 PM
igorka_91's Avatar
Thanks
Old Mar 11, 2010 | 07:30 PM
Would you use B-series keepers or K-series keepers if using the K-series retainers on a B-series head? Someone told me they are the same keepers.
Old Mar 11, 2010 | 07:43 PM
Lortt's Avatar
Old Apr 15, 2010 | 08:58 AM
turboman2.2's Avatar
wow, i never knew all this info.. would it be possible to run the rsx type s 2002-2004 valve springs on b series???
Old Apr 15, 2010 | 09:12 AM
JDogg's Avatar
stock retainers will bust with high rpms and stiffer springs.. been there done that, wont do it again.
whats wrong with TI? if they are made right and installed with a matching spring you wont have any issues at all with ti.
Old Apr 15, 2010 | 09:23 AM
negusjuda's Avatar
lol im sure you have j how is the nc weither treating you but anyway what about the portflow springs wit type r retainers and keeper with skunk2 tuner 1 cams being that they arent much bigger cams then type r cams
