i want to keep my car!!!
Old Feb 17, 2010 | 02:12 PM
hellajdm333's Avatar
Default i want to keep my car!!!
is the a thread out there for kill switch install??? i would like do to this! any help would be greats guys!
Old Feb 18, 2010 | 03:31 AM
Default Re: i want to keep my car!!!
any one?????
Old Feb 18, 2010 | 06:45 AM
95soul's Avatar
Pretty straight forward. Just run a switch between the negative wire going to the fuel pump, place it somewhere inconspicuous.
Old Feb 18, 2010 | 06:54 AM
alphalanos's Avatar
positive not negative. the wire is along the driver side sill panel. pull the panels, find the correct wire, decide where you want the switch and wire it inline with the power wire. ill try to find a wire color diagram.
here it is
http://causeforalarm.thecarthing.com...ill/index.html
Old Feb 18, 2010 | 01:04 PM
thanks guys!
Old Feb 18, 2010 | 01:21 PM
kadinz's Avatar
mustang drivers usually like to put it by the back license plate, i usually take them bahahahahahahaa
Old Feb 18, 2010 | 01:43 PM
bobbyeg6's Avatar
got oone on mine
Old Feb 19, 2010 | 01:09 AM
hondasghost's Avatar
good info!!!!
Old Feb 19, 2010 | 05:23 AM
skullbiz's Avatar
I had a switch that was hooked to the positive wire on my distributor on my rx7, but that was with a carbeurated 350 so I dunno if same applies. I'm doing this same thing. Orlando is FILLED with thieves. People don't even want to go to local car shows because they're scared of being followed home. It's bad.
Old Feb 19, 2010 | 10:10 PM
good info X2!
Old Feb 19, 2010 | 11:07 PM
'00champwhite's Avatar
or really simple, get a switch and intersect on of the wires right by ur fuel pump and put the switch where ever and u have a fuel cut off switch. Took me about 30 min. works great
Old Feb 19, 2010 | 11:20 PM
Ruben19's Avatar
for some reason, i don't like when people talk about this topic. is like you revealing all the truth about the car safety to the thieves.
just figure out yourself and don't be telling people about where the are located.
get a multimeter to find the voltage wire
Old Feb 20, 2010 | 12:09 AM
i have a hub so i take my wheel everywhere if left! and i garage my sh#t! just tryin to be extra careful! 92-95 is hella easy for those buttfu##in thieves to get!!!
Old Feb 20, 2010 | 12:59 AM
Ruben19's Avatar
^ sometimes that isn't enough
i rather not drive my car than have people see it. can't be trusting people around you specially with your car. i so paranoid but i guess that's good because i still have my car
Old Feb 20, 2010 | 01:59 AM
es01civy's Avatar
make sure you tie a relay to that switch or you are going to burn that switch up and be stuck somewhere..
Old Feb 20, 2010 | 02:24 AM
yeah i feel you!!! been doin a swap for hella seems like! so i want to rally it and show it off! and KEEP IT SAFE!!! nicest one have had so.... just wasnt sure how to do one??? cant afford a alarm!
Old Feb 20, 2010 | 02:35 AM
es01civy's Avatar
just drop ur shift linkage everytime you park haha. seriously though... just avoid bad areas, dont try to **** people off causing attention to yourself.. strap a blue nose pit to your rim every night.. all them help
nsxxtreme
Audio / Security / Video
Jun 17, 2010 08:04 AM
epicbeats
Jul 29, 2009 12:59 PM
standbackimapro
Feb 21, 2007 07:38 AM
.jacob
Dec 6, 2003 09:50 AM
JLange
Jan 2, 2003 01:24 PM
