why doesnt this oil port match the head?
Old Feb 17, 2010 | 01:58 PM
EG6 Love's Avatar
Default why doesnt this oil port match the head?
i will post this in the other integra section as well.
i have a 98 b18c type r block im using with a 96 gsr head.
why doesnt the port in the block pictured match up with anything in the head? oil is making it to the head. i ran the car for about 5 secs the other day and the cams were covered with oil. if you need anymore info lmk. i will check this very frequently.
Old Feb 17, 2010 | 02:11 PM
mouab18c1's Avatar
Default Re: why doesnt this oil port match the head?
looks like your oil hole is plugged up in your head....i like your block though
Old Feb 17, 2010 | 02:30 PM
EG6 Love's Avatar
thanks...i wanna make some big power. : )
any idea y the previous owner may have done this? are u sure its been plugged?
Old Feb 17, 2010 | 02:37 PM
mouab18c1's Avatar
the oil hole is the smaller hole in your boxed area. the bigger hole is just for your headstud. its been tapped and plugged for ls/vtec or b20vtec. oil shouldnt have made it to your head with that plugged up..
Old Feb 17, 2010 | 02:38 PM
mouab18c1's Avatar
and yes im sure it looks plugged up..it should be hallow and you should be able to see through it
Old Feb 17, 2010 | 02:46 PM
EG6 Love's Avatar
how do i fix it?
Old Feb 17, 2010 | 06:10 PM
mouab18c1's Avatar
it should be able to use an allen wrench and untap it if not then you'll have to drill it out and just be careful not to do any damage to the head
Old Feb 18, 2010 | 04:55 AM
EG6 Love's Avatar
doesnt look like theres much of an allen head left. i might be drilling.
would an extractor work?
once its out theres no further work needed to put the head on and be ready to rock and roll right? i already plugged the lsvtec alt. oil supply.
Old Feb 18, 2010 | 11:14 AM
mouab18c1's Avatar
an extractor should work if not then just use any drill bit that fits. and yes once thats out just make sure everything else that needs to be plug is plugged and you should be ready to rock and roll
Old Feb 18, 2010 | 05:30 PM
EG6 Love's Avatar
sweet!! thanks!!!
Old Feb 18, 2010 | 06:16 PM
mouab18c1's Avatar
anytime just make sure you dont do any damage to the head while drilling it out
Old Feb 18, 2010 | 10:00 PM
bigislandc2's Avatar
you cna also run a oil line from the pump to the head for more oil and less valve train wear.
we do that on most the cars we build
Old Feb 24, 2010 | 05:02 AM
EG6 Love's Avatar
GOT IT DONE GUYS. THANKS.
EG6 Love
Feb 18, 2010 04:57 AM
baphomet
Sep 22, 2005 10:03 AM
Civic TSI
Aug 20, 2001 08:17 AM
