HIGH IDLE
Old Feb 17, 2010 | 01:22 PM
supercharged d's Avatar
Default HIGH IDLE
my d16 is throwing code number 7 witch is tps. it idles at 3,000 rpm and wont change. i changed the tps and still no change...been havin this problem for a while and im startin to scratch my head now...any help is appreciated.
Old Feb 17, 2010 | 06:39 PM
delsolproblems's Avatar
Default Re: HIGH IDLE
Check the voltage of the TPS signal wire at the ECU with the engine off and the key in the ON position.
Old Feb 17, 2010 | 06:50 PM
yea it should be like 5 volts right? i did that
Old Feb 17, 2010 | 07:07 PM
No, the signal wire should show about .45v or so. The reference voltage wire should show 5v. Clear the ECU codes by disconnecting the battery negative for a moment and see if the CEL comes back. If you checked the TPS signal wire at the ECU connector, it is in the correct voltage range and you are still getting a TPS CEL then either that pin on the ECU is not connecting properly or the ECU is bad.
calebdowney
Engine Management and Tuning
Jan 21, 2013 10:25 AM
t3mppa_FIN
Oct 20, 2012 06:07 AM
marcj
Jun 17, 2009 11:18 AM
wheels01
Jul 4, 2005 05:34 PM
