steering wheel shakes under acceleration
Old Feb 17, 2010 | 10:58 AM
msinsky14's Avatar
Default steering wheel shakes under acceleration
heres my problem, just bought a new crx. i test drove the car with different wheels and there was no shaking, but when driving home from picking it up with different wheels, whenever accelerating, the steering wheel shakes. when i let off the gas, shaking stops completely. shaking is very bad under hard acceleration in access of 60mph. its lowered a lot if that helps. i dont know what to look for and already searched.
thanks for the help! im clueless!
Old Feb 17, 2010 | 11:00 AM
jonnyt1130's Avatar
Default Re: steering wheel shakes under acceleration
wheels are out of balance. hope you don't have a bent rim.
Old Feb 17, 2010 | 11:12 AM
msinsky14's Avatar
would switching out the rear wheels to the front help determine this?
Old Feb 17, 2010 | 11:41 AM
jonnyt1130's Avatar
not if the rear wheels are just as bad..go get them balanced, its cheap to do and will most likely fix the problem.
Old Feb 17, 2010 | 11:59 AM
msinsky14's Avatar
i searched on here, havent found anyone else with just shaking under acceleration that was unbalanced wheels. is there anything else i could look at while removing the wheels?
Old Feb 17, 2010 | 02:16 PM
msinsky14's Avatar
tightened up the lugs, shaking stopped for about 30 mins then hit a bumpy road and it started again. i wonder if the lugs are just backing themselves out slowly
Old Feb 17, 2010 | 02:45 PM
beansandrice's Avatar
not likly. i would go get the Wheel balance and they will tell you if your in good shape.
P. Darvan's Avatar
I had the same problem because I'm an idiot and forgot to tighten my driver's side lugs enough. I re-tightened them and it stopped shaking, but then they came loose again. It turned out I had to get new studs because they were stripped.
I'm just happy my wheel didn't fall off. Make sure your lugs are tight again. Your studs could be stripped and your lug nuts could be getting loose again. It could be dangerous!
Old Feb 17, 2010 | 02:48 PM
msinsky14's Avatar
ill keep checking them constantly when i drive to make sure they stay tight and if it doesnt get better guess im gonna have to get new studs pressed! shiiiiiit
Old Feb 17, 2010 | 03:19 PM
Malgerus's Avatar
Make sure the tires aren't worn either. Bad tires can cause a lot of shake.
Old Feb 18, 2010 | 09:16 AM
msinsky14's Avatar
im headed to have the wheels balanced today so i hope thats the problem! ill check back in and let u kno the verdict later today
Old Feb 18, 2010 | 09:22 AM
B18B1-Crx's Avatar
Bad Tie Rods.
Loose nut/nuts/
out of balance or broken rim/tire
Possibly rotor issues?
Old Feb 18, 2010 | 11:56 AM
msinsky14's Avatar
ok so i noticed today that if im moving slowly, it feels like theres a flat spot on the tire every rotation, there isnt one but idk how else to explain it. i cant find a shop with time to balance the tires in my area but im thinkin thats the issue
Old Feb 18, 2010 | 12:29 PM
4drEF's Avatar
Keyboard Humorist
You probably need new tires.
Either you actually have a flat spot or you have a bubble and the tire is getting ready to go out on you.
I just replaced a tire with a bubble about a month ago.
At first the steering wheel shook like I needed an alignment and it gradually got worse.
Eventually the steering wheel was rotating a few degrees and back again at slow speeds.
Old Feb 18, 2010 | 12:35 PM
msinsky14's Avatar
did it shake only under acceleration? mine gets worse past 3k rpm and at the top of third gear is violent shaking! i need to figure this out soon without throwing money into unneeded repairs
Old Feb 18, 2010 | 12:40 PM
4drEF's Avatar
Keyboard Humorist
It shook all the time, but when just rolling the car forward I could tell the flat spot feel happened every single time the wheel did a full rotation.
Because it happened on every rotation it ruled out everything like ball joints and tie rods.
It was definitely a wheel issue.
I guess it could have been diagnosed as a bent rim as well, but it progressively got worse - obviously tire related.
Old Feb 18, 2010 | 01:20 PM
msinsky14's Avatar
mine shakes only under acceleration except when at highway speeds, then it shakes but very mildly. above 4k rpm in 3rd gear it shakes violently
Old Feb 18, 2010 | 06:56 PM
B18B1-Crx's Avatar
CV joints?
Old Feb 18, 2010 | 08:07 PM
msinsky14's Avatar
u think it could be that my car is so low? its slammed pretty good right now, maybe binding the cv joints?
Old Feb 20, 2010 | 06:39 AM
msinsky14's Avatar
cv joints are good. had a shop look at it, they have no clue whats causing it. help!
Old Feb 20, 2010 | 06:55 AM
Deetz's Avatar
Crazy Honda Guy
OK, think i can help!!!
My 97 crv had this problem last year, i would get a shake, but only under load......
problem- bad engine mount!
I replaced it, problem solved
Old Feb 20, 2010 | 07:28 AM
Staypuff578's Avatar
i had something similar to the problem you're having just a few days ago, turns out my car was too low and was causing axle bind =(. Would'nt hurt to raise it up a notch or so and see if it helps.
Old Feb 20, 2010 | 11:11 PM
msinsky14's Avatar
my car is slammed so that would explain it. the mounts are all hasports and are all good so that must be my issue, need to raise it i guess
Old Feb 22, 2010 | 12:38 PM
msinsky14's Avatar
i had a shop noticed the camber on my front pass side wheel being more then the drivers side front, but theres no camber kit on it. he said the wheel seems loose so im thinking a wheel bearing? can a bad wheel bearing cause it to shake only under load?
Old Feb 22, 2010 | 12:49 PM
4drEF's Avatar
Keyboard Humorist
Put the front wheels in the air and grab the top and bottom (not the sides) of the wheel.
Push with one hand and pull with the other and try the rock the wheel back and forth.
It shouldn't budge.
Wheels bearings will cause vibration.
I'm sort of lost though.
You wrote that it ONLY happens under acceleration. So do you mean that it doesn't happen when you get up to speed (ANY speed) and put it in neutral?
