WOW. i feel dumb. help.
So I currently own an Ej1 with a b16a2 swap and i'm using an obd2 gsr wire harness. my question is.. will i need a jumper harness if i have an obd1 p28 ecu in my 93 civic with a b16a2 engine???
Hold on now, you're using the GS-R engine harness correct? Plugged into the the stock Civic Cabin harness at the shock tower plugs right? In that case no you don't need (nor could you use) an adapter harness. Simply use an OBD1 ECU.
to my understanding the obd1 p28 ecu would have to chipped in order to function with the b16a2 engine right???
the b16a2 is a obd2b enigine, so i would assume that you need to get a 92-95 vtec, engine wiring harness for it to work in your chassis and the p28 will plug right in
that would also work, but the all the teg harnesses are 2 piece just like the 92-95 civic harnesses. so it does not matter if the teg harness is out of a later year. The ek civic harnesses are one piece and thats why they wont work in eg's and tegs.
jdmshawn95
Jan 14, 2011 11:12 AM
jdmdikk
Apr 15, 2009 07:55 AM
2wheelhunter
Jun 4, 2007 04:18 PM
