del sol searching idle
Old Feb 16, 2010 | 05:40 PM
phantom_bcw84's Avatar
Default del sol searching idle
ok i have a 94 honda del sol vtec and i am having problems with my idle bounching from 1k-1500 or 900-1400rpms but ONLY after the car has warmed up. i have changed the fitv, iacv, spark plugs, rotor, cap, vacuum lines, tried different throttle body without the fitv and different map sensor and nothing has worked.
after all that yesterday while the car was doing the searching idle thing i disconnected the iacv and the car idled fine. again brand new part. so this tells me i need to exchange it for another iacv but im not sure. when i look at the new part and the oem part that came on the car the stock iacv there is a small whole where the screen covers and the other hole is big. on the new iacv its opposite where the big hole is under the screen cover and the small hole is just open.
so questions are do i need to replace my iacv again and also does it matter what hole is the small and which one is big?
and if you have any other ideas please let me know cuz its really getting on my nerves. thanks
Old Feb 16, 2010 | 06:03 PM
Rogue_1's Avatar
Default Re: del sol searching idle
the bouce is usually caused by the tps..although u have changed the tb's..try tapping lightly on the tps this should temp. cure the problem..if that's not it..has the computer been chipped?
Old Feb 16, 2010 | 06:05 PM
i tried tapping on both TPS's and didn't change anything. the computer is completely stock the only mods done to the car is cold air intake and a header. nothing else and those were done by previous owner. has 112k miles on the car.
Old Feb 16, 2010 | 06:29 PM
Rogue_1's Avatar
if u can get ur hands on another computer i would try it..although ur is stock..sometimes when the computers get chipped they have what is called honda idle (like what ur experiencing)..the stock one could just be messing with the tps..most cases its either the tps or the computer..other than that im not sure
Old Feb 16, 2010 | 07:00 PM
soLaLive's Avatar
hey man..my car is doing pretty much the same...check your timing it might be off by like a teeth..
Old Feb 16, 2010 | 07:10 PM
it only effects the idle nothing else. the car still pulls like hell when im on the gas hard. doesn't miss or anything so dont think its timing
Old Mar 2, 2011 | 05:22 AM
GunSamir's Avatar
Hey, I started having the same problem today on my 2004 civic. It only does that when warmed up. No CEL indicated.
https://honda-tech.com/forums/showth...searching+idle
I had similar issue few months ago, with CEL, and i fixed it by adjusting the screw. Today, that's not working.
shady3260
Jul 23, 2010 10:50 PM
schools94
28
Jul 21, 2010 07:43 PM
DJ_SaNdOz
Mar 4, 2003 08:34 AM
pdiddy
Dec 10, 2002 10:47 PM
