Car vibrates bad. help please
Old Feb 16, 2010 | 03:03 PM
polyhonda's Avatar
Default Car vibrates bad. help please
I have a automatic DD 1993 honda civic dx, I was driving for like about 150 miles,when it started to vibrate alittle. I pulled over and noticed that the whole car would shake vigorously even harder when I put it into D4. I tried starting my car up a couple times, and everything it seems like the cars about to die on me. thanks any help will be greatly appreciated
Old Feb 16, 2010 | 04:39 PM
polyhonda's Avatar
Default Re: Car vibrates bad. help please
bump for help
Old Feb 16, 2010 | 05:17 PM
Jimmy's Avatar
Global Moderator
Do you feel this vibration in the steering wheel or more like in the seat? Rough idle? Any CEL?
Old Feb 16, 2010 | 06:55 PM
Linked's Avatar
any specific speed when it starts to vibrate
Old Feb 16, 2010 | 10:28 PM
polyhonda's Avatar
the vibration starts right wen I turn on the car, and it vibrates nonstop in park/drive/reverse.
my car struggles to start ive noticed.
Old Feb 16, 2010 | 10:35 PM
sbpphoenix's Avatar
is there oil in the damn thing?
Old Feb 17, 2010 | 12:24 PM
polyhonda's Avatar
theres no oil in the sparkplugs, however, it seems that I am leaking oil from the valve cover.
Old Feb 17, 2010 | 12:46 PM
sbpphoenix's Avatar
check your engine and transmission oil levels. if it shakes on startup, something's not getting enough lubrication or your timing is off by a lot.
Old Feb 17, 2010 | 12:55 PM
97twodoor's Avatar
Sounds like you are experiencing a misfire. Check for spark on all the spark plug wires and inspect your spark plugs as well.
Old Feb 17, 2010 | 01:58 PM
Jimmy's Avatar
Global Moderator
Check all your engine mounts as well.
Old Feb 21, 2010 | 01:38 PM
polyhonda's Avatar
update, so I changed my spark plug wires and my sparkplugs. My engine mounts look fine, and my alternator is working properly. what else can be the problem?
Old Feb 21, 2010 | 06:23 PM
polyhonda's Avatar
bump
Old Feb 21, 2010 | 06:26 PM
300whpej's Avatar
oil level/seals?
Old Feb 21, 2010 | 06:30 PM
polyhonda's Avatar
I replace the valve gasket and did an oil change and transmission fluid looks fine
724chris's Avatar
do u have compression to all 4 cylinders?
Old Feb 21, 2010 | 06:46 PM
polyhonda's Avatar
yes
Old Feb 22, 2010 | 04:00 AM
97twodoor's Avatar
Have you checked for injector pulse on all injectors? Cam timing? Ignition timing? Vacuum leaks?
Old Feb 22, 2010 | 09:12 AM
Jimster480's Avatar
are you sure its not misfiring? because it really sounds like its misfiring.
Old Feb 26, 2010 | 03:07 PM
polyhonda's Avatar
did a compression test, turns out all my cylinders were 200 psi but my third was 35 psi, so I what problems should I expect when I take off the head
Old Feb 26, 2010 | 03:14 PM
Jimster480's Avatar
um a blown valve seal hopefully!
Old Feb 26, 2010 | 03:29 PM
polyhonda's Avatar
200, 200 35, 200 compression test, So I know cylinder three is gonzo, what parts would I expect to replace.
Old Feb 26, 2010 | 03:31 PM
SF_Dee's Avatar
Old May 3, 2010 | 08:55 AM
Dokta's Avatar
Depends on where the loss of compression is.
Put a few psi of air into your cylinder then listen for where the sound is coming from. Just put your ear up to your muffler, then your intake, then open your oil cap and listen in there.
1. exhaust- valve or valve seal
2. intake- valve or valve seal
3. crankcase- piston ring, piston, or cylinder wall
If the head gasket is bad it could also be coming out of your coolant system, but that's not very likely.
The only other way compression can get out is through a hole in the cylinder head, and I'm sure you would have noticed that.
Ef4doorwagon
11
Jan 14, 2014 07:24 AM
SpoonREVS
16
Jul 6, 2013 10:20 PM
my_hidden_romance
Aug 19, 2007 10:50 AM
mirza
Honda Civic (2001 - 2005)
Mar 12, 2007 11:44 PM
Mr.Hankey
Dec 14, 2006 05:27 PM
