People with the Autodynamics front lip for the 92-95 Civic, how did you mount them?
Old Sep 6, 2002 | 01:31 PM
mantic6t9's Avatar
Default People with the Autodynamics front lip for the 92-95 Civic, how did you mount them?
My lips just arrived, my car did not have the factory lip on it so i don't know how to mount the lips i have now. If you have some pics or a how to that would be great. I'm sure i can figure it out, but sence this web board is here i might as well use it to ask. Also I bought dupilcolor bumper paint but no primer, It is absolutly necessary to prime the lips before painting them. How should i prep them? When i test fitted the front lip it seemed to fit fairly well. I'm not sure if i'll use the rear lip yet, i'll have to wait for my new exhaust. It doen't seem to be compatible with the apex n1. If you can answer and of my questions post away.
Travis
[Modified by mantic6t9, 10:33 PM 9/6/2002]
Old Sep 6, 2002 | 02:42 PM
mantic6t9's Avatar
Default Re: People with the Autodynamics front lip for the 92-95 Civic, how did you mount them? (mantic6t9)
No one in 21 veiws?
Anyway, here is what i'm dealing with. I figured i would have to do something to this lip to make it fit when i bought it. The left side of the lip fits fine but the right side has a pretty big gap (shown in the pics below). Granted nothing is bolted down in the pic but i do not believe that will fix the gap. I messed with it and the only thing i can come up with is to somehow shape it to fit correctly. Anyone know if this is possible with a heat gun or hair dryer?
Old Sep 6, 2002 | 03:18 PM
fakemike's Avatar
double sided tape or pop rivets
just a suggestion, i don't have any personal experience with this
Old Sep 6, 2002 | 03:23 PM
Yokohama's Avatar
Default Re: People with the Autodynamics front lip for the 92-95 Civic, how did you mount them? (fakemike)
that second pic looks horrible...I just made the decision to go with WW RS lip...thanks!
Old Sep 6, 2002 | 03:29 PM
mantic6t9's Avatar
Default Re: People with the Autodynamics front lip for the 92-95 Civic, how did you mount them? (YokohamaSiR
thanks for the ideas, i think i can fix it.
A few different angles.
Old Sep 6, 2002 | 03:55 PM
fakemike's Avatar
maybe when its black the gap won't be as apparent. i can't even tell from the front pic. but i'm sure its easier to see in person. good luck, keep posting with your progess.
Old Sep 6, 2002 | 04:57 PM
mantic6t9's Avatar
Nah it will be fixed before it goes on the car, i'm not going to put it on unless it is. I'm heating it up now but i don't think a hair dryer will get it hot enough to mold it.
Old Sep 6, 2002 | 06:36 PM
RacerXI's Avatar
Try double sided tape to get it flush. The car looks good man.
Old Sep 6, 2002 | 07:20 PM
R_yd's Avatar
got a pic of the rear lip?
Old Sep 6, 2002 | 09:28 PM
J.P. 4rm The dPk*'s Avatar
Hey mantic if your selling ur rear lip i'll take it off ur hands.
Old Sep 6, 2002 | 09:37 PM
mantic6t9's Avatar
Default Re: People with the Autodynamics front lip for the 92-95 Civic, how did you mount them? (Spooner)
Yes I have the rear lip, but it won't work with my apex n1. When i get my new exhaust i'm going to see how it fits. From there i'll decide if i'm going to use it.
Old Sep 6, 2002 | 09:52 PM
eg_nezay's Avatar
supp bro, just saw the post and Ill help you out since I owned one be4.
Ok, the lip has 2 holes in the center area at the bottom. Just use any bolt and nut (I used 10mm)to screw them to your bumper.
The sides dont have holes, all I did was used 2screws in each side it holds very well
HTH if you have any more q's just IM me
This is a pic. of it on my old hatchie
[Modified by eg_nezay, 6:54 AM 9/7/2002]
Old Sep 6, 2002 | 10:08 PM
mantic6t9's Avatar
Default Re: People with the Autodynamics front lip for the 92-95 Civic, how did you mount them? (eg_nezay)
Yeah, i've seen your pics. Looks really nice. Did you have any fitment problems?
The lips i got came with mounting hardware and the lips don't have any holes in them. Did you prime your lip?
Here is the mounting hardware...
Old Sep 6, 2002 | 10:12 PM
BW's Avatar
BW
i just want to saw that this is by far one of my fav civics which is weird because i kinda don't like hatchies (execpt for the fact that they weigh only 2000 or so lbs)
[Modified by BW, 7:12 AM 9/7/2002]
Old Sep 6, 2002 | 10:21 PM
eg_nezay's Avatar
the only thing I used was the brackets and lined them up to the middle holes on my bumper,u understand?And for the sides I used my own 2screws and drilled it. No, I didnt primer it, just sprayed it flat black.
[Modified by eg_nezay, 7:23 AM 9/7/2002]
Old Sep 6, 2002 | 10:24 PM
eg_nezay's Avatar
Default Re: People with the Autodynamics front lip for the 92-95 Civic, how did you mount them? (BW)
THANX!
Old Sep 6, 2002 | 10:26 PM
eg_nezay's Avatar
Travis, u see this pic, put a screw on top and one on the bottom
Old Sep 6, 2002 | 10:41 PM
mantic6t9's Avatar
Yeah that's what i was going to do. I've got the mounting figured out. Just have to fix the gap on the drivers side. Thanks for the help.......
Old Sep 8, 2002 | 06:48 PM
mantic6t9's Avatar
I bought some 3M molding tape today and hope to be able to fit it, paint it, and install it soon. I'll post pics when and if i ever get it done. I know some people didn't prime theirs, but would it be better to go a head and do it?
Old Sep 8, 2002 | 06:53 PM
cleanASScoupe's Avatar
prime it
Old Sep 9, 2002 | 12:13 PM
mantic6t9's Avatar
Default Re: People with the Autodynamics front lip for the 92-95 Civic, how did you mount them? ('99EJ8)
After a Few hours of fitting i went from this
To this
That's without the 3m tape. Once that's on it shold take care of the gap. I want to paint it and be done with it but it's too humid outside. Guess it will have to wait. I'm just glad it's goinig to fit, one less thing i have to worry with. Thanks eveyone for your help.
Travis
[Modified by mantic6t9, 9:14 PM 9/9/2002]
Old Sep 9, 2002 | 03:58 PM
mantic6t9's Avatar
Finnished. Sorry i didn't have time to get any good pics.
Old Sep 9, 2002 | 04:16 PM
tooqwik1's Avatar
hey buddy nice lip
heheeheheheheh
Old Sep 9, 2002 | 04:33 PM
mantic6t9's Avatar
Default Re: People with the Autodynamics front lip for the 92-95 Civic, how did you mount them? (tooqwik1)
hey buddy nice lip
heheeheheheheh
Hey have you tried the rear lip yet?
Old Sep 10, 2002 | 11:01 AM
S2KGirlie's Avatar
you should try my lip. looks better
[Modified by racer_gyrl22, 8:18 PM 9/10/2002]
