EF rear disk brake conversion.
My newly acquired EF still has the drums on the back, and i hate em. How hard is it to do a rear disk conversion from an integra, since they are interchangeable right?? Do all the suspension parts bolt right up?? Also is there any mods needed to be done to the brake lines for them to fit into the calipers?? Thanks for the help.
Quick answer: yes it bolts right up.
Biggest pain when I did mine was routing the new e-brake cable. Also, don't forget to get a 4040 prop valve; otherwise your front brakes will be doing almost all the work. While you're at it why not get some ss brake-lines
juanito297
Nov 26, 2008 11:09 AM
MPALUGHI
Jul 12, 2008 06:55 PM
Maui Built
Oct 3, 2007 03:05 AM
soodominican
May 7, 2007 04:31 PM
