Fuel/idle Problem
Old Feb 16, 2010 | 11:50 AM
4g4dcruisin's Avatar
Default Fuel/idle Problem
Unfortunately, i think the eg that i got ended up being a little bit of a money pit...
-Runs cold, like, the temp gauge rarely goes above "C". If im in traffic, it raises up to the normal driving temp area (1/4 of the way up).
-I'm getting VERY bad gas milage, like 120-150/TANK!! It take a couple tries to fire up in the morning, not cuz the temp, because if i let it sit all day during the past couple days, it will take two tries to fire up.
-I get a tad of white smoke after idling for long period of time, goes away once i stabilize speed. Dont believe its coolant since the rad is never dry after driving 45 miles one way to work.
-Cold idle is around 1200rpm, then anywhere between 500-1000rpm at normal driving temp. It surges/fluctuates/bounces between 500-1000rpm is what i mean.
-IAT cel code 10, replaced with new IAT, cel still there even after ecu reset.
-Lastly, vac line disconnected at rear of IM on driverside, line goes to the char canister, i attached the line and the motor either boggs out, or idles below 500rpm
d15b7/z6 mini-me, running the b7 ecu until i find a p28, using the 4-wire o2 and vtec is wired up.
Im not sure where to begin, my assumptions are...
-Injector stuck open, or fails partially.
-No thermo/stuck open thermo.
-Need the p28 to get the correct air/fuel ratio.
Im stuck over all on what to do, i've heard that the IAT could directly cause bad gas milage, but im not sure.
Old Feb 16, 2010 | 12:38 PM
Default Re: Fuel/idle Problem
bump for some help.
Old Feb 16, 2010 | 12:48 PM
Red_Army's Avatar
im gonna say your thermo is gone. and causing other issues cuz of it always thinking its so cold.
Old Feb 16, 2010 | 12:55 PM
I had an EF sedan and i ran with no thermo, then with a thermo, and had absolutely no difference. Is an EG cooling system really THAT different than an EF?
But yea, i just havent had the time to really dig into the damn car yet!! working and moving doesnt free up very much time.
Old Feb 19, 2010 | 10:30 AM
BUMP
i picked up some new spark plugs, gonna do a pretty extensive tune up to the EG this weekend, finally. Im convinced my horrible gas milage and white smoke is due to the fuel injector(s).
I have a chevy s10 carbed, there is a single injector at the top of the carb and an o-ring was jacked up, so every time i'de try to fire it up, it would get flooded. When the o-ring was replaced, and everything fired up properly, i had a **** load of white smoke coming out with each rev. Eventually, like an hour later, the smoke stopped and has not since returned.
So, to try and see if my injectors are leaking, is it "safe" to remove the rail with injectors still in tact, then turn to ACC and let the pump prime? Im sure if something was leaking, this is where i'de notice it.
Also, can someone confirm that the IAT sensor malfunctioning (code 10), is directly related to bad gas milage?
Old Feb 19, 2010 | 12:14 PM
bump
Old Feb 19, 2010 | 12:27 PM
Mr.Highlife's Avatar
my sedan does the same thing.
Old Feb 19, 2010 | 12:30 PM
Which thing? i have a few things that are all connected im sure...the biggest problem is the fuel consumption, which im sure is related to the idling, which im sure is related to the IAT sensor.
The vac line going from the rear of the intake mani to the evap canister is removed. I tried to hook it back up but the idle drops down too low and the car dies.
Old Feb 19, 2010 | 12:31 PM
BiG ChOr!Zo's Avatar
wow you should of kept the sedan
Old Feb 19, 2010 | 12:40 PM
cold idle problem,always runs on C,bad gas mileage
Old Feb 19, 2010 | 12:57 PM
haha no way dude, that thing was problem after problem...at least with the eg, everything seems to be realted.
These are the parts i've gotten so far.
-ngk plugs
-oil filter
-oil obviously
-thermo
-some new injectors lined up if i see mine are leaking while the pump is priming.
EDIT: oh hey man, can you get the hook up on 6x9s?
Old Feb 19, 2010 | 01:13 PM
http://www.tegger.com/hondafaq/overh...underheat.html
I love the author of this, he knows his **** big time.
The temperature gauge takes forever to get to the half-way mark
The gauge barely moves off the "Cold" mark
My heater's output is terrible
The transmission's torque converter won't lock up
The transmission won't shift into top gear
I just failed emissions on high HCs
My gas mileage is lousy
Numbers 1 through 3 are symptomatic of a thermostat that has failed open.
Number 3 can also be a defective or seized heater control.
Numbers 4 through 7 may be related to the thermostat.
As stated here, the thermostat's job is to keep the engine running at the correct temperature, which is about 90C (194F) (depending on the model). Coolant temperature is an important sensor input to the ECU.
If the engine's temperature is reported as being cooler than what the ECU is expecting as full-operating temperature, the ECU will direct a richer mixture, which will lower mileage, increase emissions, and put fuel into the oil, which will in turn greatly accelerate cylinder bore wear. As well, the ECU will often prevent an automatic transmission from upshifting into overdrive or lock up the torque converter until it sees a "full-warm" signal from the coolant temperature sensor.
Old Feb 19, 2010 | 10:37 PM
-ngk plugs
-oil filter
-oil obviously
-thermo
hopefully you didn't buy someone elses mini-me experiment i need a pair of 6.5 speakers myself...!!!
Phillip Jones
14
Nov 16, 2017 07:17 PM
GGMK
Mar 4, 2012 04:25 AM
accordianex
Apr 3, 2007 07:30 AM
DETurbine
Apr 10, 2006 07:14 PM
village_idiot
Oct 30, 2004 05:12 AM
