replaced blown tie rod ends still clunking noise
so i replaced my blown tie rod ends but i still get this clunking noise when i drive on the freeway like a balljoint is bad.could it be my inner tie rod is bad??
i hope its that easy for you, usually its worse like broken axles, or even a broken wheel bearing. thats what mine was like a few months ago. sounds like a DUNK< DUNK>DUNK noise. good luck
Usually the rack end bushing feels worse when you are slowing down quickly, but i would check for play in the inner tie rods and the balljoints. Bad axles could be the culprit too, so check for play in them or torn boots.
its not the axles i recently just replaced them with brand new ones.just checked my inner tie rods and there's alot of play.so im gonna replace those and replace my rack end bushing just in case.its bound to be worn out for being almost 20 yrs old
