Weird Heat/Temp Gauge Problem..
Old Feb 16, 2010 | 07:23 AM
Weak!EG's Avatar
Default Weird Heat/Temp Gauge Problem..
I recently purchased a bone stock 95 integra special edition. The car takes forever to heat up compared to my experience with previous hondas i've owned. When it gets hot enough to blow heat the gauge reads MAYBE 1/4.. Sometimes the gauge goes to normal temp and the heat wont blow, then sometimes when you stop the air blows cold and as soon as you start driving again it blows heat again. Would like to get this fixed, so all suggestions are appreciated. Thanks
Old Feb 16, 2010 | 07:32 AM
PaulMc's Avatar
Painfully Stupid
Default Re: Weird Heat/Temp Gauge Problem..
I have the same issue with my '01 ITR. Only the other way around. If I let my car idle and heat up to normal, it'll blow nice, hot heat. Then I start driving on the highway, the temp gauge goes back down to Cold pretty quickly, and the heat isn't as hot.
Think it could be the thermostat?
Old Feb 16, 2010 | 07:40 AM
dpetro1's Avatar
in your case 99.9% sure its a stuck open thermostat.
for the OP, probably also a open thermostat or air in the system as mentioned in his other thread
Old Feb 16, 2010 | 08:45 PM
PaulMc's Avatar
Painfully Stupid
That's what I'm leaning towards. I hope it's as simple as that. Thanks.
Old Feb 16, 2010 | 11:35 PM
DANINE101's Avatar
Im having the same problem with my da9 plus my warning light wont turn off i dont know how to shut it off....
Old Feb 17, 2010 | 05:07 AM
dpetro1's Avatar
what do you mean by "warning light"? are you talking about the check engine light?
Old Feb 18, 2010 | 08:59 PM
DANINE101's Avatar
well i have jdm gauges its not the check engine light its the engine overheat light....
Old Feb 19, 2010 | 04:45 AM
dpetro1's Avatar
is it on all the time? even at first start-up in the morning?
Old Feb 19, 2010 | 11:50 AM
Weak!EG's Avatar
Update: replaced the thermostat and bled the system... car still has same issue.. it wont even get warm enough for the cooling fan to come on. The heat blows way hotter if your driving than sitting still for sure.. but still not right.
I also checked to make sure fan works, and it does..
Old Feb 19, 2010 | 12:00 PM
dpetro1's Avatar
Very strange. i dont know of any other reason your car would not come up to temp (other than thermostat). Can you confirm the actual coolant temperature? maybe there is just something wrong with your heater
Old Feb 19, 2010 | 01:53 PM
DANINE101's Avatar
Its on all the time!!! never shuts off.... freakin sucks!!!
Old Feb 19, 2010 | 01:59 PM
King970's Avatar
I have the same exact problem with my 95 GSR I drive for hours and the thermostat goes up to maybe 1/4 if that but I never have cold air blowing after it warms up for a couple minutes
agb22
17
Mar 7, 2017 07:11 AM
downtime1
Dec 19, 2016 02:25 PM
Weak!EG
Feb 16, 2010 05:41 PM
the soL that could
Mar 14, 2009 06:20 PM
boarding2008
Feb 1, 2009 04:00 PM
