ek4 with ITR intake manifold and TB
Old Feb 16, 2010 | 06:47 AM
nikanoras's Avatar
Default ek4 with ITR intake manifold and TB
hello guys i have an ek4(b16a2) and i am thinking to replace my stock intake manifold and TB with ITR's... i find TB and IM from ITR but are without sensors injectors fuel rail etc...only the TB and the IM .... can i use all the sensors injectors and fuel rail from my b16a2???? thanksss
Old Feb 16, 2010 | 07:17 AM
gsilvaej2's Avatar
Default Re: ek4 with ITR intake manifold and TB
bumppppppppppppppp
Old Feb 16, 2010 | 07:27 AM
Deetz's Avatar
Crazy Honda Guy
This is a poor idea and will only result in making less hp! Do not do it
Old Feb 16, 2010 | 07:29 AM
nikanoras's Avatar
a friend of mine gain 4kw after tune in a stock b16a2 with only i/h/e....
Old Feb 16, 2010 | 07:33 AM
Deetz's Avatar
Crazy Honda Guy
Yes, but you are asking about an Intake "manifold", they loose power on the B16A engine!
In intake "tube" will make 2-3hp, the header 1hp and the exhaust 2hp...not very big numbers!
why not do something that will actually make power, like cam shafts?
Old Feb 16, 2010 | 07:35 AM
nikanoras's Avatar
he gain 4kw with the intake manifold and TB only not with all the mods...i want to put all the bolts on in my car and then the internals...
Old Feb 16, 2010 | 07:43 AM
JENNY_EG6's Avatar
Why don't you start with internals?
Old Feb 16, 2010 | 07:47 AM
Deetz's Avatar
Crazy Honda Guy
probably not a fair comparison, often with such a small difference in power, that could just be a difference in the actual dyno numbers from day to day.....happens all the time
Old Feb 16, 2010 | 08:40 AM
nikanoras's Avatar
so is anybody here who can confirm this? ..... it would be better if i replace my stock IM with skunk2 pro?? worth skunk2 pro the extra money?
Old Feb 16, 2010 | 08:42 AM
JENNY_EG6's Avatar
What are you planning to do?
Old Feb 16, 2010 | 08:48 AM
nikanoras's Avatar
i am planning i/h/e, intake manifold, TB and then camshafts(itr or buddyclub III) retainers,springs etc...
Old Feb 16, 2010 | 10:34 AM
hmoobhero's Avatar
so did your friend do a before and after dyno test, or actually got a tune? cuz you can tune a stock motor and get more hp.
but people dont do this because it waste money. prob only see alil gain. rather spend the money on other things. i/h/e are the basics. internal parts are the power adder but are also expensive.
Old Feb 16, 2010 | 11:13 AM
nikanoras's Avatar
yea..he tuned the car to a dyno with i/h/e and then tune it again with i/h/e with itr IM and TB and he gain 4kw..
Old Feb 16, 2010 | 03:14 PM
nikanoras's Avatar
anyone to confirm this???
Old Feb 16, 2010 | 05:25 PM
nikanoras's Avatar
bump
Old Feb 16, 2010 | 05:35 PM
EKstallion's Avatar
bump
I have never performed and dyno'd what you are requesting. But what you need to do is use some common sense. Upgrade the intake if it flows more CFM than your current. Upgrade TB if it allows for more air. Cams if they are supported by valvetrain and will allow for more cfm flow.
Most engine building is common sense and staged.
do the math and homework and I think you will find that there will be a positive outcome even if you can not "feel" the results.
Old Feb 16, 2010 | 10:24 PM
hmoobhero's Avatar
why dont you ask your friend since his done it...?
Old Feb 16, 2010 | 10:37 PM
JENNY_EG6's Avatar
+1
Old Feb 17, 2010 | 06:31 AM
nikanoras's Avatar
i ask him but he buy the IM and the TB with the fuel rail, injectors and sensors so he change only two gaskets..
kaison
Jan 6, 2013 08:39 PM
t57b18
Mar 10, 2006 07:14 AM
Rusty Shackleferd
Feb 20, 2006 02:39 PM
88LXi68
Jun 9, 2003 03:41 PM
typer906
Dec 21, 2001 01:00 PM
