zc engine into 91 crx
there should be a code on the tranny, it should be on the outside maybe an inch from where the tranny and motor come together. find it and enter it on google or something and it will tell you the motor that goes with it. its probably a d series tranny
the ZC transmission uses an intermediate shaft and equal length axles
if you have intermediate shaft and equal length axles, you need 90-93 Integra axles
if you have a short axle on passenger side and a long axle on driver's side, you need axles for the model CRX that you have - DX or Si model, you need DX/LX/EX or Si axles - HF model, you need HF axles, unless someone has swapped the HF knuckles hubs for ones from DX/Si/LX/EX or Integra, in which case you would need DX/LX/EX or Si axles - HF axles have 23 splines where the axle goes into the hub - the rest have 26 splines
ok so its probably not lsd but i dont think they would of went threw the trouble to change the knuckle they it probably just had the crx tranmission thanks i appreciate the info will post back shortly
crxguy406
Jun 29, 2013 09:50 PM
shivic
Aug 11, 2004 06:12 PM
